Eibach Multi Pro R2 vs Tein Super Racing?
#51
So why did you set such a deadline on a critical component for your car? I don't understand this at all.
#52
Is changing ride height between track events and car shows a choice? have a little bit taller ride height for the track and have your alignment set for that, mark (or measure and keep notes) your perches so you know what height you need for the track. then lower it for the car so, raise it back up for track events?
and pics of the car since you're bragging about how pretty it looks?
#53
ah ok, pretty rare to see a car that does both...
#55
Unless you are using a kit like the one from Evasive in my previous post, the lowered geometry will never be right. The J's racing in warmmilk's picture drops the car 20mm keeping the lower arm level. However, it does nothing for the upper arm, the steeper angle with a lowered car raises the roll center and shorten's the swing arm length.
The Wisefab spindles and control arms from Evasive change the pickup up points on both the upper and lower arms.
#56
#57
Every other lowering effort faces the trade-offs of reduced weight transfer and possibly better aerodynamics vs. unknown or questionable suspension geometry. The lowered spindles do nothing with axle alignment. But even stock has lots of compromises; those are pretty short control arms, the kingpin angle is set for a high positive offset wheel, etc.
Evasive said in a post that Estonian (at least the website is in Estonian) WiseFab suspension was 2 seconds per lap quicker on their supercharged S2k. That seems like a lot but not impossible.
With any race car the questions are: what are the rules, how strong is the competition, and how much do you want to spend. About 40 years ago a friend of mine and I where watching a driver struggle with a Celica on Thompson's banking in an SCCA Showroom Stock Sedan race. The Celica's hopeless positive camber front geometry was hopeless on the banking (they didn't use pylons to keep cars off the banking back then).
He commented it takes three things to win: pick the right car, prepare it correctly, and drive it well. That driver had picked the wrong car. There are many things the S2k is the right car for, some it isn't. Based on the rules, competition, and budget, everyone has to make their own decision.
