First Hello; Tire Question; Window Idea.
I'm a new member and have appreciated your info. I have a blk/blk 2001 S2000 and have trouble on the streets not acting like a-16-year-old-on-drugs, sure is fun! I look forward to doing some SCCA Solo2 work. On 1-20 I went to the San Diego event and met some members [Brian and "the Jasons"]. I couldn't run though since I I was busy learning the hard way about the need to have your drivers licence with you. Next time!
I hope you can give me some suggestions:
TIRE QUESTION
I need to replace my rear tires and want some ideas on a good dual-purpose rear tire. I read the enties indicating that the 265 SO2 [2 sizes up from the stock 225'S] would be the best bet, at least while I'm running the origional 205 SO2's in the front, and would work to balance-out the under-steer. Agree?
Also is there sufficient space for no-problem clearance with 265's? Is there any down-side to runnig the wider tires? If not why didn't Honda use them in the first place?
WINDOW IDEAS
I haven't had time to read the archives, so stop me if you've heard this one. I found some nice inexpensive products for our awful back windows.
FIRST: BMW :rolleyes: has a $12.95 "Cover" [part #QA69778] for the Z3 back window that fits the S2k like a glove. It is a gray blanket of sorts that is slightly larger than, but follows the shape of, our back window. It has a very soft felt-like underside and denim-like outer-side. It connects with two clips on elastic straps at the door opennings of the top. It stores in a 12" X 7" reusable plastic pouch that stores in the trunk It is a well made attractive product with one notable exception: the 3 inch black "BMW" letters that are emblazened in the center. If used properly, however, they will only be visible for a minute, from the time you put it on untill you drop-the top. The idea is that this cover will prevent the (dirty) outside of the plastic window from sliding aginst itself and scraching in the process. I am going back to get another one to use as a liner for the top well. I find that dust collects on the unfrendly bottom of the well which scratches the inside of the window.
SECOND: Admit it, your window is already scratched! The best solution known to me is Meguiar's Mirror Glaze Clear Plastic Cleaner #17, and Clear Plastic Polish #10 I use this stuff on a 1957 MGA. Its present windows are 21 years old and look as good as the Honda's window.
Thank you in advance for your help
TIRE QUESTION
WINDOW IDEAS
Steve Meline
01-28-2002 11:34 PM
