Flipping RS-3 (v2)
If you aren't driving in the rain, you can just run them backwards. I did that on RS3v2 and I can confirm that perform exactly the same in the dry. I got 10 days out of my set. If you have access to free mounting, then sure, you can flip them. Judging by your tires, you could either flip them now, or else wait one more day. The very outside corner tread of the RS3 wears off very quick but there's still some rubber left below that.
I usually first make sure to get even outer wear on all four by rotating front to rear, and running backwards. After then I dismount and remount, its the reason I always buy directional tires. Ive driven and tracked on reverse direction mounted tires, its not as bad as people make it out to be especially when no standing water
I flipped mine. Ended up getting another weekend out of them until I felt they were too questionable for wet use. What are your alignment specs?
1/16 toe out in the front with neg 3 camber
1/4 toe in in the rear with neg 3 camber
I removed the wheels to take to costco to flip and notice all 4 tires had different variations of flat spotting due to locking up without ABS at VIR. Since I have 3 track days coming up in a span of 4 days, I decided to mount on new tires. Besides the bumpy ride home, the chatter and vibrations on turns were also unnerving me in the middle of turns.
