fuel starvation or something else?! (video included)
hey guys, this is happening most of the time in this uphill left turn that the engine behave littel weird.
Is it fuel starvation or something else? See between 52-55s and notice the engine sound (fuel level 80/100)
Sounds like fuel starve. Best way to describe it is you feel like you hit a Rev limiter and there is a brief delay and then it picks up speed again. Of this seems like what you are feeling it is likely fuel starve
It does sound a bit like fuel starve, does not seem like it is abrupt as I have felt but it is hard to tell that from the video. I have experienced it on Lincoln concrete at SCCA nats before at 1/2 tank. That was the only time in this car but was surprised to see it with that much fuel.
My first thought was vtec is kicking out and if so would be from oil pressure drop from pickup starvation in the pan from sloshing/g forces on that part of the track. You running any pan baffling or slosh plate?
I'm running Moroso weld in baffle
Fuel cut usually feels pretty hard and abrupt, I only had it happen a couple of times and with fuel level around half or less.
Seems you are experiencing something else here, do you log the oil pressure?
fuel starve would be easy to test. After it happens come in and fill the car and see if it does it again.
fuel starve feels like someone shut the engine off on you.
^^^ That is supposed to address the problem, so it is a bit confusing. Data logging or a quick monitor of a wideband and oil pressure gauge should eliminate any guess work there. If during the episode both look normal/steady then you know to look elsewhere. Just not sure what else it would be off the top of my head. If its repeatable in the same location of the track every time, then I have to think it something related to fuel or oil pressure. No plume of smoke exiting the car from valve cover baffling issue? Not running a catch can or possibly a full one spilling back over to intake?
