Hankook RS4 temps
Old 09-14-2018, 07:17 PM
treimche's Avatar
Default Hankook RS4 temps
Does anyone know what type of temps these tires like to run at? Doing my first track day on them and will be messing with pressures all day. Brought a digital laser IR temp gun with this time.
Old 09-14-2018, 08:00 PM
warmmilk's Avatar
idk what temps they like as far as a number goes, but they definitely need a warm up lap and then you can beat on them till you run out of gas, no need to worry about overheating them... I've done track days on them in the high 90's, granted in a bit slower and lighter car, but they showed 0 fade.
Old 09-18-2018, 07:34 AM
DanielB's Avatar
Not sure if I'd approach setting pressures that way. Rather, follow standard tire pressure turning techniques to run a few laps, come into the hot pits and immediately measure inner, middle and outer temps with a proper tire pyrometer. Measuring the surface with an IR gun isn't going to get you that far as the surface cools so quickly. You are looking for a linear temperature gradient across the tire. The actual temps don't really matter as those will be affected by the weather, track surface, how you drive, how your suspension is set up, etc. Candidly, the RS4 is a really forgiving tire and most people find that the optimum pressure is somewhere in the 34 - 38 psi range hot.
I'm on my second set of RS-4 running square 255 and aim for 38 front, 36 rear. That seems to give me the best wear with my setup. I can't feel any repeatable differences in grip moving the pressures around 1-2 psi so instead focus on optimizing wear.
Old 09-18-2018, 08:11 AM
freq's Avatar
All of this. ^^^
Old 09-18-2018, 08:17 AM
treimche's Avatar
Thanks for the suggestions. I'm new to the whole tire tech stuff. By the end of the day I was running my fastest laps with tires set to 29psi hot. Sounds like that is much lower than you suggest, but when I would check tire temps across the tire, 29psi was what got me the closest to even across the tires.
Old 09-18-2018, 08:41 AM
miamirice's Avatar
If your going to take the time and effort on tire temps, Joe’s makes a decent affordable tire probe pyrometer.
Old 09-19-2018, 05:41 AM
DanielB's Avatar
I have
this one this one
from Joe's but if I was to do it again, I'd spend the extra to get one that records the temps instead of you having to write them down. You want to measure all four tires as fast as possible and to do that with the low cost Joe's, you really need two people: one to take the measurements and call them out and the other to write them down.
Old 09-19-2018, 07:51 AM
miamirice's Avatar
I have this one from Joe's but if I was to do it again, I'd spend the extra to get one that records the temps instead of you having to write them down. You want to measure all four tires as fast as possible and to do that with the low cost Joe's, you really need two people: one to take the measurements and call them out and the other to write them down.
totally agree. And you need to do it mid session or late session but NOT after session had been flagged.
Nate Tempest
06-09-2019 04:52 AM
mweaver
13
05-14-2012 12:46 PM
DaPhatty
08-14-2009 07:31 AM
BioBanker
09-20-2005 05:35 PM
S2WOOOW
01-09-2004 12:37 PM
Quick Reply: Hankook RS4 temps
