Honda Challenge s2000 to NASA ST4...
245/40 hoosiers are as wide as a normal 275/35 tire. You'd really be stuffing 245s onto a 9" wheel. While you *could* do it, I would advise wider wheels. For example, a 225/40/17 hoosier has the same fitment onto a 9" wheel as a 255/40/17 Toyo RR. I have no idea how they get away with it, but they do.
I only made 205whp peak so I have room since I weigh 2650 on the scales with me in the car
under 7.3.2 scroll down, you will find the section of permissible aero mods for ST4.
You can do all the things listed in 7.3.2.D.1, plus the limited specific list in 7.3.2.D.2. Those are the only things you are allowed to do. So the reference to power modification factor for windshield frame or roofline change, only applies to ST1-3.
I would expect further restrictions in ST 5 and 6 when they are implemented.
Im not trying to shoot down your idea of running in ST4, and welcome the chance to run with you. Just trying to point out the rule, so you know going in. Also, I think they need to develop a specific section for ST4 rules/limitations to make it easier to understand
All this talk has got me thinking...I wonder if running a 235/40/17 would actually perform better (ie: faster lap times, not looking at shear mechanical grip) than running a 255/40 Toyo RR. 2 lbs lighter, 1" shorter for better gearing, better side wall geometry on a 9" wheel
I'll have to disagree. Highlighted in blue for TT4 they allow you to remove your windshield and frame. 7.3.2 B2 Which includes roof line change. It states "additional" limitations on top of the rules that apply to all. Just like you can run A7s but you're taking massive points for them.
