How to convert toe in inch to degrees ?
The recommended auto-X alignment setting for rear toe is 1/4" to 3/8". How much is that in degrees :confused: What is the formula to convert it ?
I did some calculation assuming it's measured at the lip of the rim. That came out to 1.7 degrees equals 1/4 inches. Where are the mathmaticians that teach "trigonometry for autocrossers" :D |
Search for "toe degrees" in the search this forum box at the bottom. Been discussed many times. The quick and simple answer is deg/2 = inches. Tho the -actual- calculation is more involved than that if you care about 4 digit resolution.
-Ry |
It's simple math. Numerator divided my denominator.
1/4" convert to decimal 1 divided by 4 = .25 1/8" converted to decimal 1 divided by 8 = .125 1/16" converted to decimal 1 divided by 16 = .0625 Oh BTW, most alignment machines will do both. I say most, buy maybe all as I haven't seen on that doesn't do both. |
Thanks Krazik, I found the thread that had the formula to calculate the degrees:
sin toe [degrees] = toe [inch] / tire diameter [inch] For example: 1/4'' = 0.58 degrees E-Z, I think you should check your alignment :D Your math is off by factor 2. |
ahhh.... I guess I misinterpreted your question. LOL
sin toe [degrees] = toe [inch] / tire diameter [inch] For example: 1/4'' = 0.58 degrees |
Sorry to bump an dead thread but if you search for "toe degrees" this thread comes up. Just thought I would post a table of toe in degrees and inches for stock S2000 sized tires (24.9 inches) and save people the trouble of busting out the old scientific calculator:
Toe in Inches = Toe in Degrees 1/16 = .14 1/8 = .29 3/16 = .43 1/4 = .58 5/16 = .72 3/8 = .86 Also the above 'simple' formula is a bit off. It is much more accurate with 2.3 instead of 2 as the magic number: Toe in Inches * 2.3 = Toe in Degrees Toe in Degrees / 2.3 = Toe in Inches |
This is an old thread but Google brings it up for "convert toe degrees to inches" so I thought I'd link to two calculators I put online. The web page calculators will convert toe inches to degrees and convert toe angle to inches at 1 wheel or total toe for the axle. You input the tire diameter and toe to get an answer:
Convert Toe Inches to Degrees: http://robrobinette....esToDegrees.htm Convert Toe Angle to Inches: http://robrobinette....eesToInches.htm http://robrobinette.com/images/S2000...ent/toe-in.jpg The Shop Manual 0.25 inch rear total toe = 0.29 degrees per wheel or 0.58 total rear toe-in with the stock size tires. |
