Intermittent "clunking" when shifting into gear after track session.
Old 10-09-2017, 02:02 PM
auric's Avatar
Default Intermittent "clunking" when shifting into gear after track session.
As the title states:
- I have been having intermittent "clunking" when shifting into gear after track session.
- Only occurs after track session and only for the first (<3) few shifts and then goes away.
- Have NOT had any trouble shifting into gear (just make odd clunk sound when shifting into gear)
- Happens after a track session
- Diff/Trany fluid were replaced 1 month ago.
I suspect mounts may be loose and the engine and driveline maybe misaligned after tracking the car.
Any ideas?
Old 10-09-2017, 05:33 PM
Chibo's Avatar
Mine does this too, I always assumed it was poor clutch disengagement and the clunk is the driveshaft suddenly loading up.
Old 10-17-2017, 10:04 AM
thepoi's Avatar
Can also be a sticky input shaft bearing—spinning the input shaft like the clutch would, but with a low enough force that the syncros can overwhelm it.
Old 10-17-2017, 10:49 PM
Singh_snisen's Avatar
Any ideas?
have you checked your trans mount? Diff mounts? I have the same clunk but mine is normal. Also maybe I can hear it cuz there only a thin sheet metal between the diff and the cockpit. Fluid can be big aswell. Track s2ks hate oem mtf.
LowFlyin'
12-08-2021 07:23 AM
124Spider
05-10-2005 09:38 PM
Prolene
06-02-2002 04:57 PM
s2k_redhead
02-15-2002 04:05 AM
Quick Reply: Intermittent "clunking" when shifting into gear after track session.
