Introducing the FPSpëc Long-Stroke Öhlins DFV
For the lower front mounts... again we start with literally raw DFV damper cartridges, which allows us to valve to spec and fill with Ohlins Race Oil as opposed to the standard oil (it's fantastic stuff, and ride quality is buttery smooth). Since we start with only the shock bodies, we had to engineer everything around them... the stamped steel sheet metal forks are well, just that, an affordable production piece meant to be cranked out for the masses. The all billet fork we produce is stronger, flexes less, has higher tolerances, and is lighter. The rear lower mounts on the other hand are made to scavenge every last millimeter so we could squeeze the longest possible shock body in the rear... you'll never need any more stroke than we've now got, and it also allows you to run helper/assist springs for even more droop travel as well as helping traction for the inside wheel in cornering.
Our goal here was to leave no stone unturned and make the best damn DFV setup that we could, rivaling suspension setups costing literally twice as much. Maximum performance at minimal cost, that can be built completely to spec was the goal here, and after driving on them during tuning and testing in the last few months, I can state (in an honestly unbiased way) that they are absolutely PHENOMENAL.
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
The goal of this kit was to provide a zero compromise suspension system for the s2000 community, obviously this isn't for everyone as the cost to make of all this is significantly higher. Öhlins did a fantastic job packing the massive amount of performance into a very obtainable price point, FPSpëc takes the incredible DFV damper technology to the next level with top tier supporting components.
Edit: Well I guess Heath and I both wanted to respond...
__________________
SakeBomb Garage (01-22-2017)
This is so sexy. Thank you guys for putting in the effort that you are for this platform.
Whenever I'm ready for the next set of coilovers I know exactly who I'm coming to talk to...
to best locate bumpstops. On the rear past we reccomend a 4-6k assist spring to soften up the inside rear to improve mid corner stability and traction on corner exit. The rear also should be switched to a 6" main spring to run an assist spring as you run out of adjustment room on the spring perch otherwise.
__________________
We did. They are genuine Ohlins DFV's... internals, externals, pistons, etc... just a physically longer DFV shock cartridge!
The rear damper stroke has been increased by 22mm (74 to 96mm including the bumpstop), they were designed by Öhlins. To fit a longer damper the low profile billet fork is needed due to the longer nature of the damper. Even with the longer damper, the low-profile fork is able to lower the car well past any sensible ride height while also giving the ability to raise the car to above stock ride height. The front fork was changed to better match the styling of the rest of the kit while being stiffer and lighter.
Are the top mounts and supporting bits Ohlins pieces as well? All of that looks perfect to me.
Being very picky I think my only main critiques would be on the quality of the edges on the billet lower mounts. I know I am being very picky but it would be nice to see the chamfers on the hard edges be just a little more refined. Just comparing to other billet suspension parts I have seen.
I would also say I don't think it is really worth it to paint the Swift springs, as it just adds costs while losing the labeled rate on the springs. Personally I prefer the orange Swift spring look myself anyway, but might as well give people the option to save that extra cost.
And on the topic of color if the Ohlins anodized gold can be matched just a little bit closer. I know matching an anodized color is very tricky though so it is what it is.
Overall great to see someone taking this step that I always wished Ohlins would have taken to offer a slightly higher end version of the DFV.
$135/ axle. We reccomend anything past 12k to run front helpers and switch to 6" main springs (a requirement on the s2000 to clear the UCA)
Edit: NVM. I am guessing you are referring to switching to 6" springs when using helpers which that makes sense.
I run 13k front springs (normal length 8" for the DFV Swift springs) without helpers and have no clearance issues with front UCA. Curious what clearance issues you guys are seeing?
__________________
Thanks for both responses, very thorough. And trust me I agree completely on the quality of the DFVs. I am on my second DFV setup with unique valving so always interested in seeing what you guys are up to with them. I can't really say I have any real complaints with my current 13kg/13kg setup and valving, but it is good to see all the little optimizations being made.
As far as the springs go, again, these are pre-production pieces and the production versions will have the swift logo and rate on them... not to worry. It's also a ZERO cost sort of thing as we do lots of volume with many top end manufacturers, we can have custom things done for us that are not available elsewhere. We care about aesthetics as much as we care about performance... they go hand in hand and we go the extra mile where other manufacturers and distributors literally phone it in. Maybe this doesn't exist in the S2000 community, but we do what we do because we LOVE these cars, not from financial motives to try to "push products" on customers. We are honest to god, true car enthusiasts... not businessmen that happen to like cars.
