Jackson Racing Dual Radiator/Oil Cooler
#107
I'm getting curious for actual track use due to some of the concerns people had with the unit failing internally, allowing mixing of coolant & oil.
I went to check out the MotoIQ article that some mentioned, but it's just really an elaborate advertisement.
Thanks.
#108
#109
they were just really tight and about an inch shorter than what would have felt comfortable. I removed the oil/coolant donut that the instructions said to keep so maybe that made a bit of a difference. But I have a sandwich plate for sensors so net net it should have been about the same.
#110
I'm really interested in this as well. I'm dying to see the following information!
Readings from the end of a 20min HDPE session
Stock/oem:
max oil temp
max/min oil pressure
max water temp
With this radiator:
max oil temp
max water temp
Stock/oem:
max oil temp
max water temp
With this radiator:
max oil temp
max water temp
