Lap belt mounting on a PCI mount
ok, I am almost at the end of mounting seats/harnesses! My harnesses are eye bolt type and can’t be changed. This works fine for everything except the tunnel lap belt. PCI specifically says not to use an eye bolt, my guess is the twisting caused by the lever arm. So I think my only option is to drill through the tunnel and do a backing plate. My question is can I drill through where the hole on the mount is an run the eye bolt through both the mount and the tunnel? The only reason I want to do this is that hole is the perfect location. My only concern is by doing so it will do exactly what they want you to avoid.
I think with a proper backing plate on the inside of the tunnel you'd be fine. Might make removing the mount more annoying though.
Ok, that was my thought, I have backing plates on the way. I haven’t put it up on jack stands yet, but I think that spot should work under the car.
Don't use a standard eyebolt for either of the lap belt mounting points. Use something like the Scroth 01324 Kit: https://www.schrothracing.com/products/bolt-in-brackets . It will greatly reduce the leverage of the horizontal sheering forces placed on the mounting point, as well as provide a lot more room for seat/mount placement.
I already mounted the outside with eye bolts and it seemed fine, I assume it is ok to leave that and add those to the bracket?
I haven't mounted the subs and lap belts yet, planning to do that any day now. I did do my research and spoke with Schroth to make sure the plan is valid. The 01324 will be used for both laps and subs and mount to the PCI bracket and OEM belt mounting, i.e. no cutting or drilling of the body. It's not yet a proof of concept but it's the plan of record at this point. The goal is to install the belts before my next event on 4/7.
