'Launching' an S2k
@ conedodger, you've really launched your ap1 that much and your diff is still in tact? Is it stock? What's your technique, do you just rev to 6k and then just dump the clutch or do you use the car squaring technique where you hold the e brake and let the clutch out until the engagement point and then let the clutch go and e brake at the same.time and give it gas? I was at the track Sunday (1/4 mile) just for shits and giggle to see what my times would be and I was scared about launching so I would just start easy and my times weren't all that great.. I've already gone through one differential and I really don't want to go through another one, but then again the first one broke the first time my car was launched when I first got it. There wasn't a drop of fuss fluid in there, previous owner, long story that I don't want to get into. Anyways so how about that technique?
I moved on to B-Mod, but still run the S on street tires occasionally.Edit: Forgot to mention, diff fluid changed yearly at about 7k miles.
I haven't gotten the best feel for how to slip the clutch for a good start on those courses with starts where not much is given up on a 4 bagger roll out. I mainly let the CDV do it’s thing with a slip at around 4,500 and modulate my left and right foot to the sound of the motor. Typically it’s just the gas peddle letting out to reduce slip to manage clutch burn. The times where I don’t launch high enough for spin, it’s usually the clutch slipping when my foot is off the peddle and I’m modulating the throttle to manage damage lol. I haven’t burned it to the point my launches get worse, run to run. When I want to spin for best launch, I pre-load the drivetrain a little by having foot on the brake and let the clutch out just a little. not really pre-load, just sets the teeth close/on each other. I rev up a few times on a rythm and on the upswing of RPMS I go to 6-6.5k typically and side step that peddle like a mofo and feather the throttle one way or another from there to manage spin. I'm getting really tired of the almost straight-away drag launch starts we have been having in my region though. One must make decisions though on how competitive you want to be. If you launch bad in my region, there goes your chance of placing well. We have a lot of good drivers that go all out. I
RS3s around 35-36psi with -2.6 camber
too much spin off the line = loose rear end for me though. Rear tires get too hot and loose grip ½ way through the run. I hate managing understeer so I try to keep my car just loose enough.
Surface, tire compound, temperature all play a role here. Bottom line is whatever you do, don't bog so the answer is either you slow roll your start or find the lowest RPM where you can get a bit of wheel spin off the line and you're good.
Sent from my Galaxy Nexus using Tapatalk 2
I really like the clubs that make a launch useless (like a tight turn, THEN the start timer) Launches are fun but they are just too hard on the cars to be doing at every event.
This! There is no magical RPM/technique that works for everyone at every site. I find as big as a 3k RPM difference between our 3 local sites as to what works for me.
As far as trying to preserve the diff, I don't just dump the clutch. I let out just until the car barely moves (to load the diff), then let out completely. It has worked well for me so far.
