Life of bearings, hubs, studs
My plan this winter was to install extended studs and was going to do new bearings and hubs while I had everything apart. None of the components have failed yet but I am doing it as preemptive maintenance since I am running Hoosiers now.
After reading through a bunch of threads I decided I am going to reuse the original hub and just order some NSK bearings and extended studs.
What kind of life are you guys getting out of hubs and bearings running Hoosiers and other sticky tires?
I get 30-40 race hours out of rear wheel bearings and reuse the hubs once and studs once. I replace the fronts at the same time, even though I've never worn one out or had one fail.
I've had ARP studs fail and have switched to MSI (supplier to most NASCAR teams) and have not had a failure since.
Another vote for MSI studs and lug nuts. They are made in my tiny hometown of Troutman, NC. I have had them on my car for about a year. I’m still happy with them, but admittedly have not abused them as much as I wanted to.
I wrote a review here...
https://www.s2ki.com/forums/s2000-ra...eview-1163334/
