Looking for geared s2ks
Old Feb 6, 2008 | 08:27 PM
icemans2k02's Avatar
Default Looking for geared s2ks
well like he title says i am looking for owners who have gears in there s2k. I have purchased some 4.77 and while i know they will enhance my low end but on a track how will the effect me? For instance what are some disadvantages to having these on the track. Any help would be appreciated.
Old Feb 6, 2008 | 09:29 PM
Turn-R-Us's Avatar
this has been discussed in many threads......they usually hurt because you will be changing gears constantly and changing in a turn which is not good.
Old Feb 6, 2008 | 09:51 PM
So you have gears? And have experienced this?
Old Feb 7, 2008 | 05:26 AM
Turn-R-Us's Avatar
no, I was going to but as I read on here I decided against it.........I just gave you a synopsis of what is said on here.
Old Feb 7, 2008 | 06:56 AM
tinkfist's Avatar
Actually, the synopsis is that gears are track dependent with respect to what is optimal. I believe a more correct generalization would be: the longer and faster a track, the taller the gears (ie 4.10's vs 4.77's) should be.
I'll look for something to add to the FAQ, it has been discussed.
https://www.s2ki.com/forums/index.ph...c=475525&st=0&
Old Feb 7, 2008 | 08:21 AM
cthree's Avatar
Administrator
It all depends on the track ^^. In most cases 4.10 or 4.44 provides the best compromise between top end, acceleration and shifting frequency. 4.77 is too low 90% of the time from my experience. I've tracked with 4.10, 4.57 and 4.77. I'm convinced the right ratio is 4.44 given 4.10 being a touch too high and 4.57 a touch on the low side. I also don't think it's worth bothering with unless you think 4.10 isn't working well on your track(s).
Old Feb 7, 2008 | 11:30 AM
krazik's Avatar
Administrator
I'm going back to 4.1 from 4.44 but I'm SC'd
Old Feb 7, 2008 | 05:22 PM
abefroeman's Avatar
hopefully all s2000s have gears when on the track. I am not sure how they would pass inspection with out them
Old Feb 7, 2008 | 08:59 PM
thanks thats what i am looking for.
Old Feb 7, 2008 | 09:08 PM
good read thanks
