Making a Sparco Circuit 2 to fit into my s2000 (video inside)
Making a Sparco Circuit 2 fit into my s2000 (video inside)
Hey guys-- after some cutting and tinkering it is in! I am still thinking about switching to different seat rails or having the seat custom mounted....we will see.
Do you think there would have been enough clearance with top if u have the seat 2-3 inches forward?
Also, is there any interior dimension difference between OEM and Mugen style HT? I doubt it.
With regard to your second question I am not sure on the differences between the 2 hardtops. i just know for time trials with NASA you must have an OEM shaped hardtop. So keep that in mind if you are thinking of TTing or HCing the car.
Yes absolutely. I probably should have stated that in the video. If you slide the seat forward more (approximately 2-3 inches) the halo wing will push against the hardtop slightly but the seat fits without trimming. You would probably still have to do some slight trimming of the outside of the right thigh bolster.
moving the seat more forward you run into the transmission tunnel clearance then... shorter people have to deal with hammering the tunnel and taller have to deal with cutting the top... i got my circuit 2 in by having it mounted by the cage builder. he cut out part of the floor mounts to mount the seat directly on the floor with a set of side mounts.
I will note, the PCI mount doesn't let people below like..... 30" inseam to sit close enough. I'm 30" and it's right about the very far range of where I want to sit when pushed all the way forward.
front seat mounts cut out. drilled 4 holes in the floor for seat mounting. 2 closest to the door i drop bolts into and the two next to the trans tunnel have welded on bolts. nuts with washers on the underside.
outside with the drop through bolts
extra welded on piece of metal for strength
inside near trans tunnel with welded bolts
Snowmants (07-18-2017)
I'm 5'6" w/ a 32" inseam. I have a PCI w/ a slider and am using a Sparco Circuit 2. I trimmed nothing on the seat and didn't modify anything on the trans tunnel, I didn't need to.
I run an OEM hardtop and still use door cards.
I don't use the seat bottom cushion right now. I would also like to remove the slider in the near future but I still likely won't need to trim the seat or modify the tunnel.
My Circuit 2 is the smaller of the two sizes.
Without the front seat mounts, is the floor pretty flat? Did you have to hammer/massage to get the floor flat?
How do you have the left (door side) planted slide miunt welded to the metal piece? Why is there also a bolt head?
