Mechanical LSD upgrade - alignment changes?
Old Oct 14, 2012 | 04:22 PM
aozora's Avatar
Default Mechanical LSD upgrade - alignment changes?
Hey there,
Just about to drop a 4.44 geared diff with a Carbonetics/ATS 1.5 metal LSD into my car and not long after, will have an alignment done.
Are there any recommendations for alignment changes after this install?
I'm assuming I might not need to run as much toe in (currently 4mm left/right)? Or run it as is and see how it goes? This is my first time running an aftermarket clutch type LSD
Old Oct 14, 2012 | 05:04 PM
CKit's Avatar
It will be pushier. I'd assume you'd need less toe or less front bar.
Old Oct 14, 2012 | 05:21 PM
speedengineer's Avatar
When I put my OS Giken in I didn't change my alignment at all. Car feels just as balanced at the limit as before, including turn in, mid-corner, and on exit.
(Note some may recall me complaining about it being very loose after the install, but I've determined that was because of the old tires I was running)
Old Oct 14, 2012 | 05:56 PM
robrob's Avatar
My car is pushier with the OS Giken LSD. Inside wheel lift/spin with the stock diff helps transfer torque to the outside rear wheel which helps the car turn. I have softened my front anti-roll bar and may have to soften my front shock settings.
Old Oct 14, 2012 | 09:11 PM
Hey Rob, which version of the Giken do you have, regular or the HPD tuned version?
Old Oct 14, 2012 | 10:40 PM
aozora's Avatar
Interesting... thanks for the responses.
Might try running slightly less toe in and see how that goes. At the moment on corner exit it can get a bit sloppy but hopefully the LSD will help that out
Worst case I can also adjust the front sway on the day...
Old Oct 15, 2012 | 04:43 AM
robrob's Avatar
PuddyMod Racing tuned my Giken but I don't know what he actually did to it. He knew it was a caged, track only car though.
Old Dec 11, 2012 | 04:46 PM
legend4life's Avatar
I'd also like to know this, does the aftermarket clutch diff allow running less rear toe in, since it helps put power down better?
Old Dec 12, 2012 | 03:46 PM
WynnS123's Avatar
I would keep the alignment the same so you can see what effect the diff has. Tune from that point on.
Old Dec 12, 2012 | 04:33 PM
ZDan's Avatar
IMO 4mm left and right, 8mm total (0.72 degrees), is entirely too much toe to begin with. I'd never run any more than half that, preferably a third that or even less, with or without the diff mod.
mball19
Apr 27, 2015 08:00 AM
devildust
Mar 28, 2013 09:08 AM
dimi
May 24, 2008 07:20 AM
d3lux
Jul 13, 2007 09:47 PM
christy
Jul 31, 2003 07:04 PM
