Nasa tt5
#81
Good luck! I run TT5 in NASA NE, let me know if you need any help getting started!
#82
As far as getting the car classed, do I just go to a local speed shop and do a dyno run then send the info to NASA? Same with weighing the car?
#83
You bought Rob Robinette's car? His website is a great resource for me to use on how to build a track car the right way. Ive currently got a harddog roll bar on the way, also will be ordering a seat/harness soon as well. Rounding corners while bracing your knee against the door probably isnt the best way to drive lol.
Take a look at the dyne rules at the link above. Basically go to a dyno and get the 50RPM output following the instructions provided by NASA. You can then upload them to a calculator or manually calculate them yourself. You can get your weights checked for free at any NASA event.
KevinATL (01-21-2019)
#84
ST6 looks interesting...it seems all NA Toyota MR2s would qualify. There aren't that many but should be inexpensive, especially with a salvage title. With a wt/hp ratio after factors of around 19, the goal may be to add a few pounds to allow a higher power level to overcome aero drag. They are all pretty low (less than 49" OEM) and narrow (around 66"), the mid-engine should help traction and braking. It should also help reduce tire drag, potentially a factor in a momentum car.
And, of course, 2006+ Miatas aren't allowed.
#85
#86
Im thinking about going with this seat along with a 5 point harness, the dimensions are similar to the Recaro PP which I had in my car once and it fit perfect. OMP RS PT2 https://www.ompracing.com/en_gb/rs-p-t-2-44715.html
Its also the right price I want to pay, I found one under $700 with free shipping. I also had my eye on the Sparco Circuit II, Sparco Ergo 1 and the OMP HTE, but it seems like at least some modifications will be needed with those. Im not really into cutting the trim in my car, as I may want to sell it one day. I say that and Im about to drill holes into the body for a roll bar and harnesses lol.
#87
Get a 6 point while you're at it.
I fit my Circuit 1 without having to do any mods, looks like I would have enough room for a Circuit 2 as well. They're usually $500ish on eBay when the coupon code rolls around.
#88
A Circuit 2 does fit. Doesn't rub the door card or the roll bar for me either. Nor did I need to trim for the trans tunnel.
#89
Also, Murray Motorsport has them for like $550 shipped. I'm tempted to get one for my passenger and ditch the cheap Corbeau.
KevinATL (01-23-2019)
#90
I'm pretty sure I do. Now you're making me second guess myself.
I had a Circuit 2 as my passenger seat but it was creating too much of a blind spot and went with a non halo Sparco on that side.
