newbie questions a stock...
I just got my 2000 s2k and I'm going to start autocrossing. I plan to run as (A stock). Could anyone give me the link to the rules? I read the sticky that is about running in a stock class and I think it was refering to AS. I'm gonna run some Kumho ECSTA V710 225 front and 245 or 265 rears. what is "xx" should I get. 225/XX/16, 245/xx/16 or 265/xx/16. I'm running the tires on stock ap1 wheels. As for sway bar should I get the saner one or should I save up alittle more and get the Small Fortune Racing one? I don't really have the money to spend 1k on a comtech one. also what about alinment. I saw what the guys that where won the nationals in the early 2000's ran but that was 5-8 years ago and I'm sure people are running newer/better specs. so could you please help me out on that.
sorry I'm sure some of this has been answered before but I've spent several hours reading and get mixed answers
It sounds like you've never autocrossed before. If that's the case, you should start out driving your car exactly as it is today - all the mods in the world won't make one tenth as much of a difference as getting a few events under your belt will.
Your right I've never autocrossed before. My cusion and his best friend have been doing it for the past 6 years. I've been to several events with them though. I live in frankfort kentucky so we have alot of county roads and I do drive them pretty agressively. Although your right about autocrossing. I've had my s2k for 5 days now and have put over 400 miles on it. 300+ at which where on back roads. Before this car i had a 3 series bmw. I know I need more practice and I need to learn the car but If I go on and set it up the way it needs to be and learn on that. I'll be able to learn quicker.
I'm just asking what size v710's I need for stock ap1 wheels, if I should save alittle more and get the SFR FSB over the cheaper saner one. I hear the saner one rubs, and what aliment settings are the best for the car.
thanks,
josh
thanks,
josh
Autocross does translate to back road driving.
Back road driving may or may not translate to autocross.
There are at least two schools of thought when starting autocross:
1. Learn to drive and then prep your car.
2. Prep your car ~80+% and then learn to drive.
I think there are advantages to moderately prepping a car first, then learning on that stable setup.
IMHO, it's not worth the hassle and cost of running R-compounds in your first year of autocrossing. The current generation of street tires are pretty amazing.
You'll learn good technique and car control on street tires faster than on R-comps as you can "get away" with a lot more with sticky tires.
If you want to learn faster, still have fun, and be able to directly apply that to A-stock... get some street tires.
If it helps, some of the fast Canucks (including the SCCA Nationals runner-up) train during the season on street tires.
There is also a provisional street tire class for 2010 (STR) that will likely be a success. Save the R-comp money and put it towards a clutch-type differential....
Also, if your cousin autocrosses... riding along with him (and/or datalogging) is the fastest way to learn.
From experience, you'll still be a beginning autocrosser long after your first set of tires wear out. Why spend the money (and have the hassle of tire swapping / trailering) in the beginning?
No need to get R comps. You'll learn more about your car & your driving when you stay stock.
ps- I talked my dads friend into bringing out his porsche 968 to the race on the 16th. do I have any chance? like if it was equal drivers would the porsche out handle the s2k? they seem fairly close in stats
thanks,
josh
thanks,
josh
www.kyscca.com
I would be glad to help you out with your setup or answer and questions, etc. There are quite a few good s2k drivers around, we usually go to the big events more often than the local due to the small lots. My S2000 is currently down for the count (blown front shocks) so I may have more time to interact if I can find a co-drive. I usually help with course design in that region so I will be there anyways. Look forward to it!
-Marc
(1)94 AS
Originally Posted by sirbunz,Jul 26 2009, 07:03 PM
Come on up to Louisville on 8/2...
www.kyscca.com
-Marc
(1)94 AS
www.kyscca.com
-Marc
(1)94 AS
would you be willing to ride along alittle bit? Do you know who mike jenson is?
here my facebook, add me, so maybe I'll reconize you when I get up there.
http://www.facebook.com/home.php?#/josh.owens1
[QUOTE=josh7owens,Jul 26 2009, 07:28 PM] Yea, I knew about that race but I doubt I'll run in it. I went to the race that was at eku today and watched/ talked to people. I'm going to race in the central Kentucky series. Its over Richmond, Lexington, etc. What
