OEM Fuel Tank setup to minimize fuel starve
#41
#42
I run into this problem on hard left-handers when my fuel level is just 3 gallons short of full. I have to tank-up after every session, at this time.
I read the previous thread on this, and quite honestly it's above my skill level. Do not know of any local race shops in the area (NE Maryland).
#43
Someone else said that in a different thread. You think they could be an issue with only 40k miles?
I assume the process is covered in the service manual? One internal, one external to the tank?
Assume no such thing as hi-flow? Just go OEM, such as from Majestic Honda?
I see:
17315-S84-A02FILTER, CANISTER #7, below (don't know exactly where this is located on the car - near the charcoal canister? Do not recall seeing when replacing the rear....):
16010-S84-A01 #1, below:
In the tank....... looks like an assembly though, not just a filter.
Anything special needed to remove and replace?
#44
Part of my theoretical problem is that we're not running an OEM fuel pump in the tank of the SSM car and the surge should have a higher flow pump than the in-tank one. We're using a Walbro 255 + Kenny Bell Boost-A-Pump in tank. Wasn't sure what I could use in a surge.
For people using fuel cells, how do you check your fuel levels? Serious question.
#45
I see:
17315-S84-A02FILTER, CANISTER #7, below (don't know exactly where this is located on the car - near the charcoal canister? Do not recall seeing when replacing the rear....): #1, below:
I see:
Check out the link below.
http://s2000.com/forums/engine-tech-...el-filter.html
#46
I believe #7 IS the Charcoal Canister itself and #1 from the second diagram is your filter assembly, along with the little pickup net that attaches at the bottom of the fuel pump.
http://s2000.com/for...uel-filter.html
#47
#48
Just upping this because i'm about to do a surge tank setup and i gained a lot of info here..
i made a quick diagram on how it would look on my ap1...
Sorry for my shitty paint skilz
( i'm running a HRC 255LPH in the tank so thats why it's mentioned on the picture )
The parts i should need:
- Ebay 2L surge tank + Bosch 044 $ 400 ( http://cgi.ebay.com/Surge-Tank-Fuel-...ht_3546wt_1163)
-7x 6AN hose ends
-1x 90degree 6AN hose end
-2x Russel 640940 $ 30 ( http://www.summitracing.com/parts/RUS-640940/?rtype=10 )
-2x Russel 640850 $ 24 ( http://www.summitracing.com/parts/RUS-640850/ )
-6AN hose
I do need to figure out if the bosch 044 has an 6AN outlet plug so i can hookup a 6AN hose end...
Seems like it will cost around < $ 600,- for this setup...
Any recommendations
-7x 6AN hose ends
-6AN hose
Any recommendations
#49
@Nyther,
Looks like it should work.
Where did you plan on mounting it?
Seems like up front in the engine compartment would be the safest.
I personally don't like the idea of extra fuel tanks, and extra fuel connections in the passenger compartment (which includes the trunk) of a vehicle.
#50
Well you got a point there but im planning on mounting everything on the spare tire location which is empty...
Mounting it at the rear of the trunk would be dangerous with a rear collission.. I also do not want it up front because of the extreme heat of the turbocharger and running more risk with a front end collission... So the spare tire place seems to be the best choice..
And most surge tank setups i've seen were located in the trunk/spare tire place...
Thanks for looking martin! I really need this mod done asap since the turbocharger just eats alot more fuel and im getting sick everytime it bogs down due to a strong agressive left hand turn...
