OEM Fuel Tank setup to minimize fuel starve
#71
Reviving this.
Someone has to have success with the hydro mat. Any DIY on it or size used? Curious if it's possible to cut a hold in the factory swirl pot and get a cross hydromat in there.
#72
I wont know if it works for at least 3 months as it’s winter up here in the great white north. I’ll report back with my findings. Total cost for this was $200. Worst case scenario is I need to purchase a surge tank and im out the $200 and a $50 gas tank. Whole install took less than an hour once the tank was empty and purged
#73
That does look like a nice, simple solution, since it can be installed through the fuel pump hole without removing the tank. Just wish it were STR legal, since I'd love to have it for track days.
#75
Yeah. You could nullify that by just always running >3/4 tank for AutoX even with a baffle, which I'm sure my local club would be fine with, but the way the rules work is that any modification not explicitly mentioned is by default illegal, even if it doesn't provide an advantage.
Road racer (01-18-2019)
#78
Test result from Buttonwillow, running Clockwise #13, previously my car would hit fuel starvation on Turn 1 at about half tank. With the fuel surge cover installed, I hit fuel starve around 1/4 tank.
so this works !
not a replacement for external surge tank, but for the price and ease of install, it's great.
Hope to test in the future at Chuckwalla CW, that'll be the real test, my car would hit fuel starve on the long left handers at chuckwalla at about 3/4 tank.
so this works !
#80
Has anyone seen this? Fuel tank baffle made by small Japanese company called Orangeball. Similar concept might be a little bit more effective although more expensive (117 USD).
http://orangeball.jp/s2000ap1fuel.html
[FUEL] S2000의 Fuel Starvation 현상 해결방안 : 네이버 블로그
