PF01SS 17x9 et 60 - 245 or 255 RE71R Tire?
Hey guys,
I am quite undecided to go for a 245/40/17 or a 255/40/17 tire to pair with a set of Enkei PF01SS 17x9 et 60. I'll most likely keep my stock ball joints and my fenders stock at this time. The car's purpose is for STR Auto-x class. Does the 255/40/17 fit without rubbing or having to roll my fenders? I am wondering if anyone here has the same set of tire and wheel combo that could possibly comment on their experience. thanks in advance.
I am assuming you are lowered? If so how much? I ran the 17x9 +60 PF01SS lowered on the Tein S Tech Springs (lowers the car about 1" from stock) with 255/40/17 squared and had no rubbing at all. You should be fine with either tire size unless you are slammed.
Thanks for the reply. I am lowered on KW V3. I don't exactly remember my ride height. I will measure it up today. I will be going for an alignment soon. Did you have to do any fender modifications? Also, what camber settings did you run?
Here's how the car sat with that exact setup:
If you are going to run STR, you will need front camber adjusters/ball joints if you want to stay competitive; the stock camber range up front is too small. You will be able to fit 255's without modification up front.
I have just ordered a camber kit set to help attain the -3 camber. Thanks!
s2kn8
01-12-2017 12:23 PM
