PSA about Stoptech brakes on track
Leaking through the bleeder, not past the threads.
That's a good idea. Thanks! Do you know if they make them without check valves? The only two piece ones I've seen have them (which I don't really want, since I like to gravity bleed).
Install the Wilwood style double part bleeder - the outer is brass and threads into your current caliper thread with some threadlock/sealant, then the smaller steel inner is used for bleeding the caliper. Should be a cheap fix, I like putting them on calipers that don't run them anyway because a siezed/snapped bleed nipple is an easy fix - undo the brass bit and replace the assembly.
Do you know what thread size/pitch the stoptechs are? I have spares from my wilwoods you can have.
I would also recommend plugging the bottom two on the caliper and trying those for the top two.
-unhook the brake lines allowing the calipers to drain
-remove the bleeder screws and clean the seats
-put some thread sealant on the bases of the Wilwood ones (have some from Speed Bleeders intended specifically for bleeder screws)
-install the Wilwoods
-bleed the calipers
Then will take it to the track on Saturday and hopefully enjoy no more leaking! Aaand then probably repaint the calipers
If you're going to buy a Stoptech kit, pick yourself up a set of these: https://www.summitracing.com/int/par...6069/overview/
M10x1.0
I don't have the exact model you bought now but I think the bleed screw is the same and it takes a 1/4" wrench.
Had to buy one just for this, stupid imperial stuff
