PSA about Stoptech brakes on track
#21
Locally a few of us have had this issue. Just needed to tighten the bleeder slightly more and the problem went away. We’ve all had st40’s for 5+ years and have hundreds of track days between us
#22
I mean, it's possible really reefing on the thing would do it, but then you risk messing up the seat worse, or wrecking the threads. I did try going a bit tighter than spec, but wouldn't want to risk going too tight. Hopefully these wilwood screws will solve the problem for me.
#23
yeah the Wilwood bleeders are quite small so don't over do it on torque, just snug is fine. You also need a smaller diameter bleed hose given the much smaller sized nipples on the Wilwoods. I just make mine hand-tight but I can see how they can get over tightened.
#25
I've replaced the bleeder screws on my stoptechs. I don't even bother with the torque spec - because it doesn't work. LOL.
I ended up tightening it more beyond the torque spec. It's really shitty, but you end up just getting a "feel" for it - just make sure to always use the same exact tool each time, so get a familiar feel and some muscle memory for it. I also gravity bleed.
I've had my stoptechs for 6 years now.
#26
#27
albertg
09-13-2015 08:40 AM
