Racebred Components - Introduction
Old 01-20-2019, 08:56 AM
RacebredComponents's Avatar
Originally Posted by Dead Serious
What class/rule book is the aero built to?
Our splitters are completely customizable and can be produced for any rule book or competition.
Old 03-12-2019, 10:52 AM
yamahaSHO's Avatar
Definitely interested in this. My trailer is not nice to having a splitter. I imagine the bumper can be left on if you install the pin from the inside?
Old 03-12-2019, 12:18 PM
Chibo's Avatar
Seems like the design needs the two bolts to be tightened down after putting the splitter on, which is a shame. I didn't realize that until I saw the Instagram video above.
By using conical washers to help locate the splitter side of the mounts and using a dowel sized to the thickness of the mount to slide over tightly the entire thing could have been retained by just the pin, which would be placed on the opposite side as this design does.
edit: The other option would be to swap these mounts from side to side, that way you could get an electric ratchet in there, but that means you need to buy their mounts and make your own splitter or drill new holes in theirs.
Old 03-12-2019, 12:24 PM
yamahaSHO's Avatar
Those bolts would be easily accessible with my cordless Snap-On 3/8 impact, especially with the welded on nut.
You could always retain it with the pin and use Loc-Tite to keep the bolts backing out.
Old 03-12-2019, 12:30 PM
Chibo's Avatar
The point of it being quick release is that you wouldn't have to pull the front bumper, so if you have fender liners the design placing the captive nuts on the bumper opening side (versus outside of car) prevents you from getting anything in there. The loctite isn't a bad idea, but you'd still want conical washers since the washer would be able to move side to side without the splitter there, whereas a conical would push the washer out towards the nut as you pushed the splitter in.
Or am I thinking about this completely wrong?
Old 03-12-2019, 12:40 PM
yamahaSHO's Avatar
You could still add a conical washer.
I like the idea of these mounts as I can snap it into place easily/quickly without help, and then zip the bolts on... provided these can be installed with everything accessible from the front opening of the car.
Old 03-12-2019, 01:37 PM
diabloAP1's Avatar
what's the point of that quick release if the front bumper must be taken off?
Old 03-12-2019, 01:47 PM
freq's Avatar
I think he means reaching through the bumper opening. I personally have some mesh there to keep debris from going through my radiator.
Old 03-12-2019, 02:16 PM
afzan's Avatar
yeah I don’t understand that
Old 03-12-2019, 03:44 PM
diabloAP1's Avatar
yeah, a stainless net is a must to protect radiator, which makes his quick release useless.
Quick Reply: Racebred Components - Introduction
