Racebred Components - Introduction
By using conical washers to help locate the splitter side of the mounts and using a dowel sized to the thickness of the mount to slide over tightly the entire thing could have been retained by just the pin, which would be placed on the opposite side as this design does.
edit: The other option would be to swap these mounts from side to side, that way you could get an electric ratchet in there, but that means you need to buy their mounts and make your own splitter or drill new holes in theirs.
Or am I thinking about this completely wrong?
You could still add a conical washer.
I like the idea of these mounts as I can snap it into place easily/quickly without help, and then zip the bolts on... provided these can be installed with everything accessible from the front opening of the car.
