Raking the S2000 - An Idea for Putting Down Power
So for years now I have played with my suspension setup and I have tried a myriad of parts and different things but never really got the car where I want it. Right now I run with Custom Urge Speced DFV's 16K front & 12K rear with OEM AP1 Bars, toe links and solid bushings, the car balances within 5lb at each wheel. The car has performed well with this setup but never felt as good as I would like. The turn in is fantastic but I just can't get power down at the apex. My first thought was to try a 1.5 way differential but driving my wifes Porsche at the last event it hit me. Why not rake the car a bit, shift a 100# from the front to rear. Knowing the turn in is amazing and Porsche needs to be trail braked into the corner maybe this will help a bit. I figured I would ask and see if anyone else has tried this out and if not I might reconfigure this winter and give it a shot.
Raking the car won't shift F/R weight much if at all. Cross weights are adjustable, but left/right and front/rear balance are a function of c.g. location, wheelbase, and track, i.e. they're essentially fixed unless you move masses around.
DavidNJ (11-13-2017)
Run wider tires in the rear. This will maintain your turn in, but increase the traction envelope to rear and allow you to get on the gas sooner. It will mimic more a Porsche on corner entry with some more tendency to effective stable trail breaking.
Lowering the ride height in the rear, will remove some of your turn in response, but it will make the car more planted/stable in rear under breaking and turn in, especially if you dont run a wing.
I think you should probably mention the kind of power you're making
To elaborate the car makes Stock power, 190WHP at best. I run 245's at all corners as it is a TT car. I run the car slick with no areo. Biggest compaint about the car is the ability to put down power off thw apex, maybe better weight transfer is needed with a more advanced damper, as I mentioned earlier the diff?????
Great point on the weight distribution there will be a minor difference with a rake but it would take many inch's to see a big change.
Also good point on the braking stability, the car does tend to dance a bit in heavy breaking, nothing bad but more stability would be a nice bonus.
Have you considered playing with the swaybars? I run a very similar spring stagger as you but my front swaybar is much stiffer and my rear much softer. My car is also about a quarter of an inch lower in the rear than the front.
I've never had issues putting down power, what tracks are you running?
Thank you for the input!
Since I have been trying to keep the car in TTC I have had to remove my bars. In the past I ran a Eibach, Moddiction, AP2 rear....... With TTC most likely going away I will probably put the Moddiction and AP2 rear back if they settle on TT5.
I do think I am going to check my ride height and ensure it is level and if so then add 3/8" to a 1/2" in the front first.
I run 1/2" rake...feels good
