Roll bar, race seat - Is OEM seat belt safe?
#21
Thanks for all the feedback. I decided to go ahead and get the full setup. I've already got the Schroth Flexi harness. I'll be picking up a Necksgen REV2 Lite and hitting up a local motorsports store (Stable Energies) to try on HANS compatible helmets.
#22
you can drill your own helmet and install anchors for your HNR. I did not replace my current SNELL-2010 helmet. I just drilled it and added posts/anchors for my HNR.
#23
You pick your own level of risk that is acceptable...
For a while (6 years), i did this with the OEM roll hoops with just a seat.
That is no longer acceptable for me with where I am in life and how I currently view and value things.
I now run an RSG bar with 6-point, HNR, and aftermarket steering wheel.
#24
#25
#26
Harness isn't going to cost more than $150 I would definitely get at least that, HANS is what $300? I had my helmet drilled at the track by discoveryparts when I bought a HANS
When you crash you will move around allover the place even with a 5 point let alone a 3 point belt.
I crashed once at maybe 45mph into concrete with HANS, 5 point and my head went to the side and up far enough to give me a pretty nasty concussion hitting my helmet on the hardtop here is a video:
I think I had too much coffee that morning I was overdriving for sure
#27
Good that you were ok. Did your arms flail against stuff at all? How tight was the 5th belt now called a negative-G belt? How badly damaged was the car? Was the chassis repairable? In Spec Miata and Spec E30 crashes like that often cause the chassis to be scrapped.
#28
it was pretty bad but mostly in front the control arm mounting points. Tt was fixed it is kind of tweaked, a lot of broken stuff, a-arms, steering rack, bent subframes etc
bellwilliam
01-11-2011 09:13 AM
