Rotors look normal from R-16 track use?
I can't say I'm thrilled with the life of my R16 fronts at this point. After 3 Track days they are are roughly 50%. I switch back to the Gloc street pads before I leave the track and I still have some pad smear as well. Not sure I'll be buying another set.
I also have a Stoptech and Urge rears, and the only pads that have ever touched them are Glock R12's in the back which I leave even for street driving, and then the R16 fronts for track use and the 6 or whatever the street pad is. I'm still getting smearing on the front.
I would never turn/refsurface a track application rotor. Either keep the same pads or use a pad combo to clean them. But either way, if its not shaking and braking is fine... I dont see a big problem here.
either ur car is heavy or u don't have any ducting at all. I assume ur on the st-40 kit? Iv abused my r16 pads for 3 track days of temps over 115. They r still 80% ish.
Also wanted to stick with the max streetable compound in the rears to avoid changing them all the time with stock calipers being a pain but the R16F/R12R bias is not good for me, it's very front heavy. I definitely need more rear pad. I wish someone made a bias adjuster for our cars.
I'm on the same pad setup as u but I have no complaints but I guess my car is 2300lbs too that's y. I never overheat, glaze my brakes. Whenever I slam on them after a straight, they r always there with the best bite.
