RSG Roll Bar
#21
Air bag light can be reset with this procedure
https://www.s2ki.com/forums/s2000-un...-light-525191/
you don’t need any special connectors. I’ve done this with a 2” piece of bare wire before. Although not super easy. You need the seatbelt installed though or put a resistor in there.
Not sure how to reset the other lights but I would guess they are on because that wire was damaged. That system is self clearing though. If there is truly nothing wrong those lights should go away.
I would not track my car without abs for fear of flat spotting a $300 tire.
#22
Damaged or disconnected ABS sensor? Since you have no SRS light I would be looking in that direction. That would trigger ABS/VSA. I'm not sure how these would be related to the air bag light. May be 2 separate issues. (Also is the air bag light separate from the SRS light?)
#23
UPDATE.
- Disconnected the battery.
- Re-installed Passenger Seat and Seat Belt.
- Re-connected Battery.
- AirBAG Light is now OFF.
- VSA (still) and VSA /!\ (new) is now on.
- ABS Light Still on
- ABS sensor cable was NOT damaged as I mentioned above.
Have not performed the DTC reset trick.
Noticed new problem on test drive.
- car shudders braking
- braking is NOT confidence inspiring
- car was at track prior to install of roll bar
- I don't recall rotors warping, but they feel like it now.
Can a warped rotor set off an ABS malfunction?
#24
#25
chop that corner that sticks out off. at least i did, i didnt like the thought of having that sticking out in there. i had seen it suggested on other rollbar install threads aswell. i think the hard dog roll bar was the same. i just torqued it and its been more than fine
ca86108
04-11-2019 06:52 AM
patinum
04-24-2011 09:00 PM
