S2000 Stock class autocross information
#161
Squared is preferred... but not on stock, staggered wheels. You are running staggered wheels therefore you need to run staggered tires. When you upgrade your wheels, if you want to run a square setup, make sure they're the same width on all corners.
Yes, 255 is too wide for a 7" wide wheel.
#162
Correct if by "Stock" you mean "Street".
And for good measure, a link to the Street Class rules: https://dk1xgl0d43mu1.cloudfront.net...pdf?1484692275
Originally Posted by Section 13.4
Any type wheel may be used provided it complies with the following:
A. It is the same width as standard and as installed it does not have an offset more than ±7.00 mm (±0.275”) from a standard wheel for the car. The resultant change in track dimensions is allowed.
B. Wheel (rim) diameter may be increased or decreased 1” from the standard part.
#163
Yes, thanks, I read the rules for street class.
I was confused because I read in this thread that a square setup with 255 all around was ideal. I did not know why that would be posted if you cannot fit 255 on stock width rim up front and you cannot change the wheel width per SCCA street class. I thought this was a Street/Stock class thread, I am new to autox and these rules, thanks for the clarification.
So I should plan on 245/40 front and 255/40 rear tires to run on stock sized wheels in B-Street class, correct?
#164
Yes
245 front, 255 rear.
245 on the front 7" wheels leaves a very pinched looking tire but seems to be the preferred setup.
The 255 on the rear 8.5" looks just fine.
#165
also I am trying to clarify why it was stated previously that 255 all around would work, why state that if the wheel width cannot be changed in this class, was there a recent change to the rules?
I am not concerned about looks of the tire on the rim, just performance and safety.
thanks
#166
I know about the widths. I am trying to clarify the sidewall size for both front and rear.
thanks
thanks
If people are referencing that setup in this thread titled "S2000 Stock class autocross information" then they need to stay quiet and stop cluttering the thread.
Rules changed ~4 years ago where Hoosiers/Race rubber was not allowed in Stock class, but the ability to go up or down a size in wheel size(not width!) was added.
#168
yes.
#169
I was looking on tire rack and found these wheels that look like they would be legal in B-Street class for the AP2:
OZ Racing Alleggerita HLT
Front 17"x7" 49mm offset
Rear 17"x8.5" 59mm offset
https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&wheelMak e=O.Z.&wheelModel=Alleggerita+HLT&wheelFinish=Anth racite+Painted&autoMake=Honda&autoModel=S2000&auto Year=2007&autoModClar=
Would these wheels be ok for B-Street class?
#170
