S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Racing and Competition (https://www.s2ki.com/forums/s2000-racing-competition-11/)
-   -   Which Schroth Harness?? (https://www.s2ki.com/forums/s2000-racing-competition-11/schroth-harness-1220843/)
Rambizzle Dec 2, 2024 05:48 PM
Howdy! I’m installing a EVS Tuning Race Spec Roll Bar for my S2000 and need a harness! I already have a Recaro bucket seat. I’ve narrowed it down to a Schroth 6 point…but there’s so many! Any advice on which model exactly to Order? I will be using a HANS device too. Also what hardware/bolts/plates should I order? All input would be appreciated!
https://cimg6.ibsrv.net/gimg/www.s2k...d4f7d45df.jpeg
https://cimg7.ibsrv.net/gimg/www.s2k...32efcf1d6.jpeg
jiepo Dec 2, 2024 09:59 PM
Good read:
https://robrobinette.com/S2000Harnesses.htm
The Flexi 2x2 would work well. The lap belt can be configured both pull-up and pull-down so you can figure out which works best for you.
If you frequently change drivers, stepping up to the top-of-the-line Enduro could be beneficial for ease of adjustment.
Other good brands to compare with are Sabelt, Lifeline, which can offer similar benefits and quality at a lower price point.
acov Mar 4, 2025 12:02 PM
i have a similar setup as you - same seat and a custom rollbar . when i reached out HMS motorsports here's what they recommended to me. i ended up going with the enduro. I would recommend the Flexi 2x2 for your application. You can swap the laps so they are pull up or pull down by changing the hardware from side to side. They will definitely work with your seat and head and neck device.
https://www.schrothracing.com/item/f...x2/fia-6-point
If you wanted to get a little more fancy the enduro 2x2 is a really nice belt. It is identical to the flexi belt other than the lap belts. On the enduro the adjuster is the piece that plugs into the camlock getting the adjusters up at the perfect spot so it has no potential for interference with the seat.
https://www.schrothracing.com/item/e...x2/fia-6-point
AFK-S2K Mar 10, 2025 09:31 AM
I have the Profi 2x2 and its been great. its soft and comfortable and easy to tighten while in the car.
© 2026 MH Sub I, LLC dba Internet Brands
