Seats, sliders and rails..oh my.
Hello all. I've read almost every thread on s2ki regarding seats, sliders, rails etc. I'm kind of on information overload right now. I was hoping someone could help me out.
Im looking for a set of racing seats for the 2010 season. I've pretty much decided that I want to go with the Sparco Evos or Bride Zeta seats (though i'd like to hear suggestions). I want something single piece.
I'm a really tiny guy, 5'6", 110lbs, which is making it hard to research which rails to get. It seems like most of the threads are people asking how to LOWER the seats. This is the last thing I want to do. I'd like to at least keep the stock seat height, or maybe even raise it 1" or so. I have the harddog roll bar installed to give me a lot more clearance so this shouldn't be a problem with my height.
I was also thinking of maybe keeping the passenger side lower in case I have a taller instructor.
Can anyone help me decide which rails to get? Like I said, i've read so many different things here that my head is spinning.
Finally, if anyone could recommend a reputable place to buy them, that would be great. I need them installed before march 1st
thanks!
thanks!
My wife is shorter and lighter than you. She fits in a Sparco Evo with standard rails.
Built into the side of the bucket are vertical adjuster holes. It won't be too low for you, I promise.
You can mount the passenger seat without a slider rail and that gives maximum headroom for the passenger.
One thing to note: depending on your proportions, you may not be able to comfortably reach the pedals while strapped in the back of the bucket. The Sparco rails don't slide forward as far as OEM seats.
We had our speed shop modify the rails forward ~2 inches so she has full adjustability.
Also at the settings we use, the seat is probably a good inch or two higher than stock.
That's the beauty of a real race shop with welding skills. They make your car YOURS. If they can weld roll cages, they can do this kind of light fab work.
Thanks! That's really helpful.
Do I need to get this special "base" along with the side mounts?
http://www.sparcousa.com/pseats_acc.asp?id=537
and should I buy the "static" side mounts:
http://www.sparcousa.com/pseats_acc.asp?id=155
or the adjustable ones?
http://www.sparcousa.com/pseats_acc.asp?id=152
Keep in mind the Bride seats are not FIA certified.
A recent, relevant thread in the NY Metro forum:
https://www.s2ki.com/forums/index.php?showtopic=762280
To anyone else looking at seat rails, the BuddyClub Super Lowdown seatrails aren't worth the money. The welds holding the mounting brackets to the sliders break off:
https://www.s2ki.com/forums/index.php?showtopic=703146
Yes on "special base" both sides.
Track slider on driver's side.
We use static sides. They look sturdier to me. The seats and rails are so tight in the cockpit that I'm not sure there'd be clearance for the adjustable ones.
Note that you can't really use the 3-pt belts at all once you go to a race seat.
1 Post
thanks!
thanks!
