Splitter diffusors are no joke. On the DDESS' car that won street class in november SLB, the addition of those tunnels added enough front downforce to shear the sheet metal splitter mounts (replaced with dev sport)
I would run the splitter without them first, and see if you have enough wing first. We found he had barely enough with the type 7 voltex at max angle, which is way more drag than a non boosted car can make use of. I have had spats on my car for a while. There is a high speed drag advantage for sure. I would strongly urge you do find your splitter height and drill a locator pin hole for a small self tapping screw through both halves of the devsport bracket. The slide bolts can move and the splitter finding some angle on the track will result in a lot of drag, then the splitter hitting thr ground, then no more splitter. |
Originally Posted by anorexicpoodle
(Post 24550051)
I would run the splitter without them first, and see if you have enough wing first. We found he had barely enough with the type 7 voltex at max angle, which is way more drag than a non boosted car can make use of. I have had spats on my car for a while. There is a high speed drag advantage for sure. I would strongly urge you do find your splitter height and drill a locator pin hole for a small self tapping screw through both halves of the devsport bracket. The slide bolts can move and the splitter finding some angle on the track will result in a lot of drag, then the splitter hitting thr ground, then no more splitter. I think I have enough wing, it is a 68" 9Lives with the Emissive endplates. I have a few ideas to test at NASA Arizona Motorsports Park in a week (front will stay as-is plus spats), then I will likely have a couple of front diffusers to test for NASA Chuckwalla in February. Thanks for the heads-up on the PLA getting melty as well, I definitely printed mine in PLA so I'll print in PETG before attaching anything. I think you are all right that the hood / fender venting is another low hanging fruit area and you're making me reconsider being completely against doing it..... it would be nice to have a car that is one color again. :rofl: Dave linked some good videos and I really do think that a curved design that draws from the center area of the splitter and forces air into the tire area might be one of the better options we have based on common existing mount (DevSport) location. I'll draw something up this weekend because I think a large diffuser like I printed can only really be run in single configuration and in the center of the car based on places that they can fit and have an area to deposit air. I'd be curious to see where others have mounted the Professional Awesome ones. |
Originally Posted by Chibo
(Post 24550251)
Thank you for the warning, I drilled some locating holes this evening. Added advantage is it is easier to pull off / put back on since you don't have to mess with lining up some sharpie marks. :) Also started doing some cardboard aided design for spats. How did you attach yours and what material did you use?
I think I have enough wing, it is a 68" 9Lives with the Emissive endplates. I have a few ideas to test at NASA Arizona Motorsports Park in a week (front will stay as-is plus spats), then I will likely have a couple of front diffusers to test for NASA Chuckwalla in February. Thanks for the heads-up on the PLA getting melty as well, I definitely printed mine in PLA so I'll print in PETG before attaching anything. I think you are all right that the hood / fender venting is another low hanging fruit area and you're making me reconsider being completely against doing it..... it would be nice to have a car that is one color again. :rofl: Dave linked some good videos and I really do think that a curved design that draws from the center area of the splitter and forces air into the tire area might be one of the better options we have based on common existing mount (DevSport) location. I'll draw something up this weekend because I think a large diffuser like I printed can only really be run in single configuration and in the center of the car based on places that they can fit and have an area to deposit air. I'd be curious to see where others have mounted the Professional Awesome ones. Are you running TT? If so any splitter features basically stuffs you into TT3. TT4 requires a flat splitter. |
(Post 24550251)
I think I have enough wing, it is a 68" 9Lives with the Emissive endplates. I have a few ideas to test at NASA Arizona Motorsports Park in a week (front will stay as-is plus spats), then I will likely have a couple of front diffusers to test for NASA Chuckwalla in February. Thanks for the heads-up on the PLA getting melty as well, I definitely printed mine in PLA so I'll print in PETG before attaching anything. I think you are all right that the hood / fender venting is another low hanging fruit area and you're making me reconsider being completely against doing it..... it would be nice to have a car that is one color again. :rofl: Dave linked some good videos and I really do think that a curved design that draws from the center area of the splitter and forces air into the tire area might be one of the better options we have based on common existing mount (DevSport) location. I'll draw something up this weekend because I think a large diffuser like I printed can only really be run in single configuration and in the center of the car based on places that they can fit and have an area to deposit air. I'd be curious to see where others have mounted the Professional Awesome ones. PLA can handle about 120 degrees in my experience. You can up that a little by heat treating them in your oven at the glass temp, or even coating them with high temp paint. Since you already have them, throw them on and give it a go. |
Originally Posted by roel03
(Post 24550299)
If you send me your diffuser files and rough estimate of how you're mounting them I can run them in my S2000 model, probably this weekend. Give you a rough estimate of before/after.
(Post 24550263)
Strong likelyhood ill be at CVR with NASA in Feb as well.
The Viper ACR front splitter ended up with 12 distinct diffusers; Chrysler was a little desperate to get downforce to match the large rear wing.
https://cimg1.ibsrv.net/gimg/www.s2k...ce34fce088.jpg https://cimg0.ibsrv.net/gimg/www.s2k...66b4841f95.jpg |
I need some confirmation on appropriate venting locations.
I was thinking of printing a similar large duct like Chibo has and mounting it in the center of my splitter in between some Dev-Sport brackets and having the end of the duct rise vent right in front of my radiator, see pictures below: Some questions -Will this create a pressure zone that reduces the effectiveness of my radiator? -Will venting into the engine bay in front of the radiator negate the downforce effects since it will be venting into an "enclosed" location? http://i67.tinypic.com/2lkpwmv.jpg |
(Post 24550934)
I was thinking of printing a similar large duct like Chibo has and mounting it in the center of my splitter in between some Dev-Sport brackets and having the end of the duct rise vent right in front of my radiator, see pictures below: Some questions -Will this create a pressure zone that reduces the effectiveness of my radiator? -Will venting into the engine bay in front of the radiator negate the downforce effects since it will be venting into an "enclosed" location? Right now I have my splitter all the way to the front jacking point. I ran a 15"x10"x3" center diffuser on the rear of my splitter CFD and got 30% more front downforce, with negligible drag penalties (simple model of course). |
