View Poll Results: Welding AP1 front UCA mount
Do it as a preventive measure
25
78.13%
Wait until it shows signs of failure
21.88%
Voters: 32. You may not vote on this poll
Spot weld upper CA as preventative?
I should have known I wouldn't get a straight answer on this . So am I welding them or not?! If there is the possibility of damage that could make it more difficult/costly after failure then maybe it isn't a bad idea to do them as a preventive, but is this the case?
According to Bullwings, you're being irresponsible if you don't get them welded.
So many variables ......
It's like a HNRS, the chances of you actually ever needing one is pretty low -- but when you do need one, you're going to wish you had.
Preventative maintenance is cheaper than repair. You have access to a mobile welder- that makes the answer even easier. Is it needed, probably not. Will you be more at ease once it is done, yes
to clarify I will always have access to the welder, it is just coordinating our schedules to find time. I want my car back together!!
