spring rates for jrz singles
I have jrz coil overs and at the moment i have 550front and 400 rear rates, and i am looking to go to a softer rate, and i am looking for input. i was considering going down to 400front and 375 rear, the car will be 90% street driven, 225f/255r tire sizes, toyo t1r's not race tires. Im looking for more comfort, still performance minded of course. Does anyone else have any suggestions or opinions on that change? also where is the best place to buy springs for my shocks? do i just go through eibach direct or is there another/better place.
thanks
CHRIS.
thanks
CHRIS.
I have had 400/400 and recently went to 500/450, but haven't tracked it yet with the new rates.
Your F/R ratio is pretty high.
I'll trade you a pair of 400's for your 550's, or if you really want to go nuts I have a pair or 800's. I assume you're running the 8"x2.5" sizes.
does anyone else have experience with 400/400 setup? From what i recall going to a softer front without going a softer rear as well will give me some oversteer, is this true? any other info would be great
CHRIS.
CHRIS.
chris,
I have an '01 with
450/450 on Bilstein PSS9's
Stock F bar/No R bar
OEM 16X7.5 at all four corners with 245/45/16 RA1's
TC anti-bumpsteer kit
For me it is very neutral at the track AND "just" streetable.
Cal
I have an '01 with
Cal
CHRIS.
CHRIS.
Originally Posted by mikegarrison,Feb 7 2007, 08:54 PM
All else being the same, this would give you less understeer and/or more oversteer. But what is important here is the sum of the wheel rate due to the springs and that due to the sway bars.
bgoetz
07-23-2014 06:39 AM
s2konroids
10-27-2008 06:26 AM
