Stoptech C43 Competition Front BBK Review - Page 2 - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 Racing and Competition
Reload this Page >
Notices
Old 08-13-2018, 10:33 AM
Ricky_Flowers_'s Avatar
Oh wow, that's pricey. I thought for some reason they were in the $1950 range.
Ricky_Flowers_ is offline
Old 08-13-2018, 11:37 AM
You're correct!
https://www.s2ki.com/forums/sponsor-...-kits-1186234/
afzan is offline
Old 08-13-2018, 12:45 PM
Originally Posted by DanielB View Post
The front BBK shifts the brake bias forward 13%. That's not an insignificant amount.
I'm pretty sure that is not correct. You may want to call them and ask but I think at most 2%.
HammerBro129 is offline
Old 08-13-2018, 01:32 PM
DanielB's Avatar
I believe the 2% claim is referenced to the ST40, not stock. The actual difference is 7-8% more than the ST40 depending on the height of the pad. The Evasive site calls out a DR21 pad shape. The pad height isn't called out so I initially estimated it at 40 mm. Just now measuring on my screen indicates it's closer to 41.5 mm. I've updated the spreadsheet and if anyone has access to pads and can provide a real measurement, please let me know.
Putting it all together (math is in the spreadsheet), the C43 BBK generates 7% more brake torque than the ST40 and 12% more than stock. Again the math is all in the spreadsheet - if there's a mistake I'm happy to correct it, but I think it's accurate. It's pretty basic physics.
DanielB is offline
Old 08-13-2018, 05:04 PM
What spreadsheet? Show me your math. The pad annulus is 40mm. I would just call them and ask because it't not always that basic believe it or not. They are very helpful.
Old 08-13-2018, 05:38 PM
DanielB's Avatar
Thanks for clarifying the pad height. I've reset to 40 mm in the spreadsheet. The link is in my first post but here it is again for convenience.
https://docs.google.com/spreadsheets...it?usp=sharing
With all due respect to Stoptech, their numbers should be close to the math - if not, then something is not right. Sometimes the information gets altered as it transfers from engineers to marketing people. I've had that happen far too often in my professional life to just accept numbers when they don't align with basic math and physics. Again, if you don't mind, please review the math in my spreadsheet and if there's an error, I'm happy to fix it.
FYI, I'll leave it to others to call if they choose. I already have a BBK
DanielB is offline
The Following 2 Users Say Thank You to DanielB For This Useful Post:
Chibo (09-04-2018), freq (08-15-2018)
Old 08-13-2018, 06:33 PM
Hymm not sure. I think your math is correct but like I said I am willing to bet there are other factors as they are designed to work with OE rears and not throw off the balance. They did tell me that the force point isn't always assumed to be at the center of the pad. Looking at the sheet though I am pretty certain the Spoon's piston size is off. I measure mine at about 36 & 40mm.
Thanks,
Brook
Old 08-13-2018, 07:52 PM
Jub
Just out of curiosity, why is this limited to 00-05. What is different about the 06+ that these will not work?
Jub is offline
Old 08-13-2018, 08:38 PM
DanielB's Avatar
Thanks,
Brook
I'm sure you are correct that the center of the force point is not the center of the pad, but I think it's a good enough approximation when we're comparing kits where the rotor diameter and pad height don't change very much. I think to get the exact center we'd need to define the shape of the pad and integrate across the area. Not sure my calculus skills were good enough when I was in school, and they have only atrophied since
Changing the piston diameter to 36 and 40 makes a significant difference: the front bias drops to 7% which is 2 percentage points more than the ST40 kit. So that's probably the issue - the website data is inaccurate.
DanielB is offline
Old 08-13-2018, 09:23 PM
it isn't. But you need a slightly different kit because the brake lines are different
afzan is offline
Quick Reply: Stoptech C43 Competition Front BBK Review
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
