Track day tires—faster and/or better wearing than RE-71R
Yep, it's another tire thread...
I've been contemplating getting a second set of wheels for track days. Last season I just ran on RE-71Rs, which were plenty fast, but I went through two full sets in about five track days and about 7 autocrosses. Would love to get a bit better wear, and ideally go faster in the process... (And without paying twice as much per tire.) I know the other thread is talking about RS4s, which sound good, but I'm looking for something at least as fast as the REs. I don't currently have a tire trailer, but I wouldn't be totally opposed to getting one if necessary. (On one hand it would probably be a bit of a waste just for track days, but on the other hand it would make it much less likely I'd get stranded at the track. And it would mean I could run the tires a bit lower on tread since I wouldn't worry about my day ending if I corded one unexpectedly, since I could always run the REs as a backup.) So, if I have a trailer and just want to go fast I guess I'd be looking at a Hoosier R7 or BFG R1. Not sure those would be any more economical than the Bridgestones though, as I doubt they'd last much longer, and they're more expensive. Intermediate option looks like something like a Toyo Proxes RR—still faster, but likely to wear better too? Potentially Trofeo R, but I'm not sure those would fit my fenders at the front, as I'm running pretty close with 255s, and they run wide. Anything else in that range, or thoughts on how the RR stack up against the RE-71R? Then if I don't want to deal with the trailer, options would be maybe Proxes R1R or R888R? Not sure how these stack up in terms of wear or performance though. What do you guys think? Obviously track days aren't timed, so I don't need the fastest possible tire. On the other hand, I don't feel like going to the hassle of switching wheels every time just to save a bit of treadwear, so I'd like something that's at least a bit of a bump. Also our local club does run a couple of casual time attacks each season, so going faster for those would be a nice added benefit. |
What autocross class are you running? STR? If you are going to be fast in STR at competitive autocrosses (there are always days when 3 cars show up) your tire choices are limited and so far the RE71r is at or near the top of the list and has been for 4 years (2019 with be the 5th, very long for a competition tire).
Are the track days competitive events? If not, why is going fast important? In addition to tire wear (there is a reason the tires you listed have a TW of 40 or 100 vs 200 for the RE71r and all STR legal tires). Fast tires tend to be sacrificial, at least in the resins that give them their adhesion and maybe in the tread itself. A lot of people seem to like the RE71r and the A052 on the track. The A052 is not STR legal because its initial tread depth is 1/32nd to little. If it was, it would probably be giving the RE71r and Rival S 1.5 a run for the money. But high adhesion tires put all sorts of additional stress on the chassis because of the higher cornering and braking forces. If the car had enough power to make traction marginal, they would also put an additional drivetrain load (drag racers break also sorts of interesting stuff, a look at the FI forum here will show the mod some people needed as their cars went to 600hp, 700hp, 800hp, or higher. You may remember AP1 cars had a problem with their upper front control arm mounts in track day and competitive situations. That said, your track day car probably isn't limited to 255. Lots of people run wider tires an wheels, but some fender reworking is necessary. |
Yes, I'm in STR, and I'm already on RE-71Rs. I also use the car to do several non-competitive track days and a couple of competitive but small, local time attacks each year. So yeah, like I said, it doesn't need to be the fastest tire in the world—if I just wanted be be as fast as possible I'd get some A7s and burn through a set each day or two. But as far as why going fast is important, mostly because going faster is more fun than going slower. I'm already used to the car on RE-71Rs, and I don't feel like taking a step back in performance. (Also don't want to go wider than 255, since I want to be able to swap back to my autocross tires and stay STR legal.)
Yes, the RE is a "200tw" tire, but it's not really. It's an autocross tire, designed to be as sticky as possible while nominally meeting 200tw, and not necessarily to withstand high temperature. Everything I've read suggests that dedicated track tires, even with lower treadwear ratings, can last much longer under track conditions, without giving up grip. For example, it's commonly claimed that the NT01 is about as fast as the RE-71R once it's up to temp, but lasts much longer on the track. So that's one option. But my thinking is, if I'm going to switch wheels for track days, rather than similar performance and much better wear, I'd ideally like to find something that would offer somewhat better performance and somewhat better wear, if such a tire exists. |
The A052 do sound like they might be a good option. Can drive them to and from the track, faster than the RE71R, and a bit longer lasting, based on the Tirerack reviews. Anyone tried both?
https://www.tirerack.com/survey/Surv...irePageLocQty= |
Originally Posted by Nate Tempest
(Post 24556000)
https://www.tirerack.com/survey/Surv...irePageLocQty= A bunch of the reviewers at Tire Rack have had both. They tend to favor the A052. But not STR legal, so it is an extra set of wheels and tires. Typical: Tire: Yokohama ADVAN A052Streetable Track & Competition Vehicle: 2004 Honda S2000 Miles Driven on Tires: 1,500 Location: BURLINGAME, CA Driving Condition: Track/Autocross Driving Style: Spirited
1,500 Miles on Tires February 14, 2018On my 3rd set in a row. The grip is phenomenal in the dry. Turn in is razor sharp. VERY predictable at the limit and easy to control pass the limit. I was previously on re-71r's and the grip on these is just next level. The re-71r's would last me 4 summer days (75F+) and about 5 winter days (55F+). The grip level on the 71's would drop off after about 2-3 days. Theses A052's I'm able to get about 5 summer and currently on 7winter days going on 8. Grip does slightly drop but I'm still able to consistently get within .2-.3 of my PB at the end of its life. For reference, at Lime Rock the fastest lap was a 59.8 sec by Parnelli Jones in a Boss 302 Mustang. There are S2000s beating that at track days. Is it really necessary to go faster? For just track days, I think I'd probably invest in better data acquisition that aided driving and chassis setup improvements. |
If you want to be competitive in Autocross, keep RE71R's. They're the only 200TW that will perform with that type of warm up.
For track days, I highly recommend Hankook RS4. They take 1-2 laps to warm up, but they wear like iron. I put 12 days on mine last year (well they were actually RS3...but basically the same). The RS4 have marginally less total overall grip when warmed up and don't become so greasy at the end of sessions like the RE71R do. So, in short, it just depends what you want. |
@DavidNJ
Yes, I saw those reviews, but I'd be curious if anyone has used them on an S2k (as well as any of the other tires I mentioned, or others!) Regarding wider tires with fender work, as I said, I want to remain STR legal. |
Originally Posted by HawkeyeGeoff
(Post 24556010)
For track days, I highly recommend Hankook RS4. They take 1-2 laps to warm up, but they wear like iron. I put 12 days on mine last year (well they were actually RS3...but basically the same). The RS4 have marginally less total overall grip when warmed up and don't become so greasy at the end of sessions like the RE71R do. So, in short, it just depends what you want. I mentioned the RS4 in my original post. Not quite what I'm looking for. I'd like something that offers at least slightly better treadwear than the RE on the track, but is also at least as fast. That's why I was throwing out ideas like the Proxes RR, R1R, R888R, or now the Yoko A052. The latter sounds like a slight step up from the RE in both wear and grip for track use, but it's still a street/track tire, so I'm curious whether something like the RR might be more what I'm looking for. (Or even something like the BFG R1, but I'm guessing that will wear at least as fast as the RE71R.) |
(Post 24556012)
Of course I'll be keeping the RE71Rs for autocross.
(Post 24556012)
IMO I was pretty equal on either RE71R and NT01, the difference being that RE71R started quicker but got slower after about 3 track days. The real difference was my buddy stuck with his RRs even though they were IMO significantly degrading after each event. See below plot of time delta between us over the course of the season: For roughly equal lap times and greater tire life, you could go NT01. I'm going to try the A052s next year, hopefully a bit faster and longer-life vs. RE71R... https://attachment.outlook.live.net/...animation=true |
