Tracking Stock Car - Need Oil Cooler?
#21
All good points. This is kind of what I was expecting, unfortunately. Half and half on to go with it, or to leave it out. The pro's of throwing it in are obvious, but when looking at my plan of 'keeping the car as simple as possible' it makes me think twice. Coming from a turbo car, i want to keep this car as simple as possible.
#22
Proper safety equipment is quite pricey and a big commitment, whereas an oil cooler is what ~$400? I know plenty of people that track w/o an oil cooler and are just fine.. It just seems like something that's relatively inexpensive for some peace of mind and should provide some benefit. I ran an oil temp gauge for a cpl years before installing an oil cooler.. To each their own..
#23
Well let me tell you what does kill an S2000 motor. Running out of oil. When you introduce multiple fittings and multiple lines into the oiling system you are multiplying the risk of an oil leak and a catastrophic motor failure. Adding that cheap oil cooler might mean peace of mind to some, but it is added complexity that is otherwise unnecessary to me. I have seen plenty of oil cooler leaks on multiple cars.
This right here.
It comes back to does the cooler help temps? Yes. Is it needed? I dont know. Is it worth the extra fittings, lines, heat exchanger, It would be stupid to not consider that an extra risk in reliability. Sure, people run coolers all the time with no problems. The possibility of a leak, or a crack in the exchanger, is still there.
I can see this discussion going on. I think it may come down to testing.
#24
#25
The other thing to consider is that when fitting an oil cooler that although your temperature worries may disappear, many forum members seem to change that worry to oil pressure woes instead LOL . You only need to see the numerous posts of people with oil coolers now noticing and complaining about a drop in oil pressure when the thermostat opens. Seeing as the F20C engine requires very good oil pressures to operate properly, I would rather have good oil pressure and mediocre oil temps than good oil temps and mediocre oil pressure....
Given that oil changes are relatively inexpensive (and after watching the Endurance video I posted up earlier, where a standard car only reached a peak of 134•C (273•F) in 36•C (97•F) ambients) after 20 laps of extreme driving, I think I would rather worry about temp than pressure issues, as 1. I wouldn't be stupid enough to do 20 laps back to back and 2. We're lucky to get 26•C (79•F), let alone 36•C (97•F). I am sure after watching how the S2k performed in these extreme conditions, that doing 7-10 back to back laps in the temps we get in the UK is unlikely to see more than 125•C (257•C).
For me that is acceptable and I just perform an oil change every other track day to ensure the protective quality of the oil is maintained.
Obviously you need to just assess which is more important to you based on the way you drive the car and the typical temps you are likely to experience .
#26
Coming from a turbo car, I will now be tracking a stock car. I have an oil cooler laying around. Should i put it on my stock car? Are oil temps getting high on stock cars at the track? These are HPDE events with the hopes of time trials in the future.
If I do put the oil cooler on, Should i leave the factory cooler on? The after market one does not have a thermostat on it.
#28
A bit more information about the mocal thermostat sandwich plate. It does not close 100% completely; it always circulates a little bit of oil. It's my understanding is so that you don't have a sudden rush of very cold oil flowing into the engine which could cause some issues. So when I drove to the track and the air temp was in the 30F-40F range, I taped shut part of my front bumper opening.
#30
Ultimately yes an oil cooler is another failure point (something I've thought about as well), but I think it provides a benefit to me. Tracking a stock car, definitely not necessary, but if you start modding it, going faster, adding rubber, aero, etc. It's probably good to have.
Regarding pressures, very hot oil results in a pressure drop also. I compared my oil pressure before and after oil cooler and I'm getting very similar pressure (before and after oil cooler), but with cooler oil. Putzing around the street, I don't see a significant pressure drop as the thermostat doesn't appear to open enough to affect the pressure substantially.
