Trying to understand braking behavior
hit the pedal hard. if you can't engage abs, i would bleed the brakes.
to answer your question, it is not difficult to engage abs in this car, and it's not subtle, you will know when it is engaging.
Sooo either something was different during the autocross causing it to not engage (like brake fade, but I really don't think they were worked anywhere near enough for that), or more likely, it was engaging, but I didn't notice it. I suspect what was happening was that in the particular situations where this happened (like cresting a hump), there just wasn't a lot of braking force available. That would make the pulsing less noticeable, and in the heat of the moment I was more focused on the fact that the car wasn't slowing as fast as I'd expected.
So, probably nothing to see here. Thanks for the suggestion to do the obvious test!
Well, to be fair, the ABS on this car is more subtle than a lot of cars. My E46 was smack in face noticeable, the S2000 I need to be calm and listening to the car more closely.
The feel of ABS in this car may not be as obvious as others, especially in the heat of racing, but it's still easy to engage.
Try slamming the brakes on a wet surface or gravely surface. If you can't feel it, something is wrong.
