What Seat? 2018 - Page 2 - S2KI Honda S2000 Forums
Notices
What Seat? 2018
Old 07-12-2018, 02:08 PM
Barnburner3's Avatar
I would definitely recommend the PCI bracket, great piece of work, gets the seat very low, good price, and very robust and well-engineered.
If FIA certification is not a requirement I'd look into the Corbeau FX1 Pro. It's basically an EVO 2 copy that's just as comfortable.
I use mine just as a passenger seat since I came across a steal for a Sparco Circuit after I had already bought two. I'm 5'11", 168 lbs, 30 inch waist so pretty skinny but I have plenty of room. I've given rides to guys more your size that said they were very comfortable and a buddy of mine uses one in his Foxbody that's more your size that likes it.
Barnburner3 is offline
Old 07-12-2018, 02:28 PM
weenrock's Avatar
If you get anything Sparco, make sure you get a rail that will fit. I have the Sparco Evo and the Ngasia rails won't fit it. The Evo 1 is much slimmer than the Evo 2. I ended up going with the PCI mount. A little bit more but so worth it.
weenrock is offline
Old 07-15-2018, 04:22 AM
Why no mention of OMPs?
im looking for my first seat as well - similar size and similar problems w the broomstick. A local shop pushed me towards OMP, but I can't find anyone who's out one into an S2K before!
NoDelta is offline
Old 07-15-2018, 12:08 PM
OMP HTE-R 400 can be made to fit, Arro has installed one. https://www.s2ki.com/forums/s2000-ra.../#post24179227
Kenny_Stang is offline
Old 07-18-2018, 09:01 AM
If you want a street/track seat and 34" waist hands down the Recaro PP would be on my short list. I tried a an EVO2 and found it a little more snug (I'm 180 5'9") and it's definitely harder to fit in the car. I ended up selling it and getting a Recaro PP. It drops right in and is more comfy. Don't overcomplicate things and just get the PP.
SlowTeg is offline
Old 07-18-2018, 03:36 PM
freq's Avatar
I'm kinda surprised to hear all the positive comments on the PCI mounts.
I'm short, 5'6", and I had to cut away a TON of the PCI to get my Sparco Circuit 2 to sit low enough for me and I still don't use the bottom cushion.
Maybe it's because I sit so far forward? So much so that the side mounts hang out over the front OEM seat mount points.
freq is offline
Old 07-19-2018, 08:23 AM
That's likely the case because of the raised front mounting point.
Old 07-20-2018, 07:10 PM
Could you explain this a little bit more? I'm a shorter guy as well (5'7") and everyone complains that I sit very far forward (I think my legs are a little proportionally short apparently). I was planning on getting the PCI mount with a seat but if it won't be compatible with me then I have concerns. How does a forward seating position interfere with seat mounting? What was preventing the seat from mounting correctly? Was it contacting something?
Thanks!
Shift9303 is offline
Old 12-11-2018, 11:01 PM
Trying to get a sparco ergo with pci here.
im 5”7 160lbs. i am also worrying about seat positions and everything but harness position is a big concern.
From my research, if shoulder holes on seat are too high or too low, its not going to pass inspection or even if it did, its not safe.
anybody has experience with these combination or similar?
How do i know im good to go with seat and seat mount?
i am sharing my car with my wife.
she is shorter than me 5”3 probably 120lbs.
Palnning to put slider on seat obviously, but wondering that seat hits hardtop or somewhere if she move seat to forward.
theS2K is offline
Old 12-12-2018, 04:35 AM
freq's Avatar
I have a set of sliders I'll sell you.
I have a Sparco Circuit on a PCI mount, it wasn't plug & play for me at 5' 6".
What roll bar do you have? My Hard Dog has the lower(ed) harness bar. The PCI mount might make your sub harness mounts difficult too.
It may not be fun and will likely be some trial and error but it is so worth it.
freq is offline
Quick Reply: What Seat? 2018
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
