Why not more camber?
#31
Originally Posted by DavidNJ
Very impressive picture! That car looks well setup... nearly the only giveaway is how lightly loaded the inside tires are.
- Did you need to go to OS Giken or other Salisbury differential to maintain power with the lightly-loaded inside tire? The decal implies you did.
- Since the tires are 25.6" diameter vs 24.7" for the OEM size, how adversely affected was the geometry?
- The stiffer than common front springs help keep the geometry in check?
- Was their stiffness determined from testing?
- Did they help keep the tires out of the fenders under braking? I'm guessing you pull some of the highest braking forces of any S2000.
- Hoosier has that size (and lots of sizes around it) in both 17" and 18" wheel diameter. Why did you choose the 18"?
#32
zeroptzero
03-27-2016 07:15 PM
DaveZuck
12-15-2011 12:01 PM
