Your Experiences vs WRX (non STI)
Originally posted by alexf20c
Not necessarily.
Not necessarily.
I drove the STI straight for about 2 weeks after I got it, and I jumped back in the S with H&R coil-overs. Let's just say I MISSED S so much that I had to go attack some favorite local twisties. But I just put a set of JIC FLAT2 on the STI, now it's almost as good as the S, almost..
gotawd=Thanks for the comments, just curious - could you elaborate more on the Gearbox and DCCD - (what exactly is that) on the Sti?
nevert00fast=Your assumption about the straight line is correct - I figured that the STI would smoke the S from a standstill pretty bad, so I specifically made sure to denote (non-STI) Take Care
SHIRI=YOU'RE A LOSER.
Gearbox-STI has a 6 speed vs. the EVO's 5 speed. Also, the STI's shifter has a better feel than the EVO's. The transmission is also said to be better in the STI.
DCCD-Driver Controlled Center Differential. It gives you the option of splitting the power from 50/50 lock to 35% to the front and 65% to the back, or you can leave it on auto and let computer do the work.
[QUOTE]Originally posted by nevert00fast
Yah, it would be slaughter. Your run in with the STI is different from what I'm assuming changomo is asking about. He's talking about racing in a straight line, from a stop or a roll a stock S will lose to a stock STI pretty bad. Now your run with the STI was over miles of twisty roads, where handling and driver ability is more important than HP.
