2005 s2000 Alignment specs
Just as the title says... Ive been searching for a while now.. and i cant find the answers i want.. Iam looking for all possible Alignment Specs.. (UK alignment, JDM Alignment, North American Alignemnt).. I wanna know the pros and Cons for each setup. Its a bone stock ap2 with 215/255 setup in tires..
What Do u guys Recomend here.. Its only gonna be for street driving only...
Thanks guys for all your help....
The factory settings are in your owner's manual (page 184 or somewhere around there). The camber settings are given in degrees and minutes, so you'll have to interpolate them for the technician into degrees (-1 deg 30 min = -1.5 deg). Toe is given in total toe (0.14"= 0.07"L+0.07"R). The alignment shop can and should align your car exactly to spec (not within tolerance +/-). Either you or someone of similar size should be sitting in the drivers seat during the alignment. The technician needs someone to turn the steering wheel anyways, so they shouldn't object.
