30k mile service for S2000 cheaper than other cars?
I just took my Accord in for a major service (30k/60k/90k). It cost me $340. I asked the servie rep how much it would be for my S2000. He told me it would be cheaper since I wouldn't need spark plugs and wouldn't need to rotate the tires.... He quotes me $280.
Something doesn't seem right to me. How much do you guys usually pay for this service? My car needs a valve adjustment pretty bad. |
Sounds pretty good to me. I did mine at Menlo Honda up here in SF bay area for $310+tax. They originally quoted me $340 but when I told them I had a K&N drop in and wouldn't need a replacement, they knocked off the replacement cost. Btw, I did expect it to be more, but I'm not complaining. :) Good luck!
Whoa don't I repeat DO NOT EVER do a manufacturer's recommended service like a 30,000 mile one. You are getting taken to the cleaners and then some! They charge you up the ass for things like "check brake pads" which don't need to be checked and you can do it for nothing. Get an oil change, if you need to get a new air filter and put it on yourself. Don't be a victim!!! You can do your own spark plugs too for hundreds less than the dealer charges.
I'm due for this service as well, but haven't gotten to it quite yet. What all is entailed? Can I do it myself and save the cash?
[QUOTE]Originally posted by djohnston
Whoa don't I repeat DO NOT EVER do a manufacturer's recommended service like a 30,000 mile one. |
Most of these you CAN do yourself, if you are comfortable doing so.
Normal driving conditions: 30,000 mi/48,000 km/2 yrs Replace engine oil. Check tire inflation and condition. Inspect front and rear brakes. Replace engine oil filter. Check parking brake adjustment. Inspect tie rod ends, steering gear box and boots. Inspect suspension components. Inspect driveshaft boots. Inspect brake hoses and lines (including ABS). Check all fluid levels, condition of fluids and check for leaks. #Inspect exhaust system. #Inspect fuel lines and connections. # = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual. Replace air cleaner element. Replace rear differential fluid. Replace dust and pollen filter. Inspect drive belt. Severe driving conditions: 30,000 mi/48,000 km/2 yrs Replace engine oil and filter. Inspect front and rear brakes. Check tire inflation and condition. Inspect tie rod ends, steering gear box and boots. Inspect suspension components. Inspect driveshaft boots. Replace air cleaner element. Check parking brake adjustment. Replace rear differential fluid. Lubricate all hinges, locks, and latches with multi-purpose grease. Inspect brake hoses and lines (including ABS). Check all fluid levels, condition of fluids, and check for leaks. #Inspect exhaust system. #Inspect fuel lines and connections. Check all lights. Inspect the underbody. # = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual. Inspect drive belt. Replace dust and pollen filter*. * = See dust and pollen filter on page 187 of your owner's manual for replacement information under special driving conditions. |
I agree with the others. I doubt the dealer even does all those things on the list anyways.
