For all those who got the clutch replaced.
I finally got mine done, i must say the car sounds waaaaaaay better. I can actually hear then engine and other noises now that used to be covered by the rattle sound.
One thing though, the new clutch # is
P/N 22200-PCX-025
Reading through some old posts i noticed some people saying that the new number was:
P/N 22200-PCX-005
This is wrong.
This happens to be the old clutch and if you got this one you got an old one back.
You can see this info on the TSB-055 as well. The new clutch number and failed clutch number mentioned above are both there.
One more thing, the Canadian TSB for the 1-2 grind also had a 1000 KM break-in warning not to exceed 5500 RPMs, unfortunately i don't have a copy of it to scan, it is at the dealers.
By the way, if you havn't done the clutch fix, DO IT, it makes the clutch 4-3k rattle much much quieter.
[Edited by Sev on 03-03-2001 at 09:57 PM]
P/N 22200-PCX-025
P/N 22200-PCX-005
This is wrong.
Originally posted by Bernie
Sev
Can you explain what the clutch fix is? Is this a recall?
Sev
It is a TSB and is replaced free of charge.
Originally posted by Sev
Honda has developed a clutch that reduces the rattle noise that comes when decellerating from 4000 to 3000 RPMs.
Sev
Sev
Thanks Sev
Do you know from what period the new cars have the new clutch in them? I haven't heard of this before
Thanks Sev
Sev
Sev
Thanks Sev
No one really knows for sure, if you have a "waaaaaaa" noise in 2nd or 3rd gear from 4-3k rpms coasting that mostly goes away as soon as you put your foot on the gas, then you have the problem.
Originally posted by SpaceNeedle
So do the 2001 models have the 025 clutch?
