Anybody here use Race Ramps?
#21
Before I bought my QuickJack, I made my own cribs for something less than $20. You can do all four wheels with two (2) 2"x12"x12' planks and a few feet of 1x2 or 2x2 for chocks. I used them for something like 20 years. I gave them to a fellow S-owner after I got the QuickJack.
short round (06-18-2019)
#22
I priced it out and the amount of wood I would need, using 2x10s, was a lot more than $20, so unless you can find the wood cheap or have a source, not as economical as it appears for most; wood is heavy and gets tiresome moving around the shop and certainly not as convenient to transport if you are going to a track event; splinters!
#23
Build vs buy. That equation will differ for each of us. How much our time is worth, our skills and tools for construction of whatever would be built, money saved, etc.
When I was younger, and broker, and time wasn't worth as much, it probably would have went the other way. But today, for me, its buy.
My concern though is my driveway is sloped. Concern is the base isn't wide enough, and they would topple over. Anyone have experience with sloped surface with these?
With the jack stands, I often place a strip of wood under downhill side of stand, to make it sit level. Perhaps I could build a wedge or something to place under the cribs to make them level?
Of course, now we're buying AND building...
CH53Driver (06-16-2019)
#24
I think that it's reasonable to assume that if it cost me $20 at the time 20 years ago that the compound effect of inflation over that period might make today's cost twice or a bit more that twice than my original cost for framing quality boards. Not one splinter over 20 years.
Home
I am not affiliated with any of these companies that I have discussed, just so no one thinks I am trying to be a shill for a specific product. The OP wanted to get input on RR and being I own this product and think they are the best option on the market for the price and safety, I have nothing but good things to say about them. I used to have a set of the RR service ramps for my GT500 about 10 years ago when I had one. That car was 3800 pounds and front heavy, never had any issues with those ramps sliding when pulling up or backing off of them and they were solid. Can't say the same about the Rhino ramps. I tried a set of those for my wife's RAV4, one kicked out on me while pulling up onto them causing the other one to fail. I can provide pictures of said ramp if anyone wants to see the evidence. Went off like a shotgun when the one failed, fortunately I was in the vehicle and nothing was damaged other than the ramp that failed.
#27
I did the same, except mine don't look as nice, and are way heavier, more awkward to move. Yours are inspiring.
But the ramps I have suck. Its almost impossible to get the car up first shot, as one or both ramps will shoot out from engine torque at the rear. Or for the front if I brake too early it shoots out. My sloped driveway doesn't help.
#28
I finally bought the XT ramps and couldn’t be happier. Yeah they’re very pricey but the amount of lift it provides along with its ease of use makes it worth it.
Thanks to everyone who replied to this thread especially to @BootsS2K and @CH53Driver for the pictures you guys posted.
BootsS2K (10-20-2019)
#29
I built a set for mine out of wood. 6 pieces of 2x6 cut into the ramp shape and glue laminated together. Plenty strong, but heavy and clunky :P With the STR setup I only have about 3.5 inches under the pinch welds so the rears have to be pretty short to work. But that just gets it high enough to get a jack under it to the center jack point. Buying is really a better option and they will be lighter/easier to use. But I had a bunch of scrap and had the table saw out, so I just built em :P
My thing with the race ramps (The bigger longer ones) is I am oinly going to get the rear up 3.5" max since that is the tallest thing that fits under the car. So unless I am just needing to do something to the rear part of the exhaust, need clearance for an oil drain pan (I have a quick valve so do not need to get under it to take the plug out) or touch a sway bar, then the ramps are only good enough to get it high enough to jack up. So most times, I just use the 4 pieces of 2/10 I originally made to drive it onto so I could get the jack under it anyways
Gernby
06-11-2004 01:26 PM
