Anyone ever remove the underhood liner?
Might save a pound or two, but your probably looking at a good bit more sound, and heat I believe (I forget where the heat issue comes in...).
If you just want to replace it, there are some alternatives such as a spray on insulation that is applied thinly and ends up being light and easy to clean.
There are quite a few people who have removed it. Billman has ran without it for over 3 years. I have ran without it for a year.
If you have a stock exhaust manifold it is not louder at all. If you have an aftermarket header, it will be slightly louder.
A lot of racers have actually removed it, not because of the 2 ounce of weight savings, because it will catch on fire!
Go for it.
Go for it.
Go for it.
Go for it.
Thanks.
Heat soak, that's what I was trying to think of (sorry almost done my 8 hours of labor and can't think quite straight
). If you remove the underhood liner, the painted metal acts as a reflecter for your engines heat, sending it back down into the engine bay. For a high-reving hot engine like ours, this can be bad.
So instead just get a new hood with vents!
). If you remove the underhood liner, the painted metal acts as a reflecter for your engines heat, sending it back down into the engine bay. For a high-reving hot engine like ours, this can be bad.So instead just get a new hood with vents!
Originally Posted by bkmagby,Aug 31 2006, 10:55 AM
Do you have any pictures of what it looks like with out it? Any heat issues, or issues of it affecting the paint?
Thanks.
Thanks.
Regarding paint fading from removal... I would say it would take around 10 years depending on your climate. That is how long it took my truck to do it. When the S is 10 years old, you will be worrying about other things! My Accord is 16 years old, 4 of which on a DC Sports header... paint hasn't faded one bit. I am sure this is one of those "Your results may vary" things.
I believe it's just for sound insulation although I've also heard it's a fire suppression device (melts during an engine fire smothering the fire???). As far as engine heat, I think it acts like a blanket retaining engine bay heat. The exposed underside of a hood should be a heat sink drawing heat out of the engine bay IMO.
