Brake Calipers
1 Post
You don't need to remove the caliper to replace the pads, they just swing up out of the way of the pads. You will not need any "special" tools, just good old metric wrenches/sockets.
The one tool I would say is not optional is a torque wrench for the wheel nuts. The design of the Honda relies on the wheel nuts to be torqued evenly. If the 5 nuts are not even it will promote rotor warp. Get a torque wrench if you don't have one already.
Quick and easy job.
Originally posted by Rdriver
Don't you need a special tool to compress the rear piston?????
I know you do on some Honda's.....
It's designed to rotate the rear piston, but I find them to be almost worthless.
A lot of people just use square shaft screwdrivers or something similar. There are also custom tools like the set here designed for the job.
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=40732
Originally posted by reecespieces
also pick up a C-clamp to push in the front piston, makes it much easier.
