S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Talk (https://www.s2ki.com/forums/s2000-talk-1/)
-   -   buttomed out on speed bump (https://www.s2ki.com/forums/s2000-talk-1/buttomed-out-speed-bump-1062887/)
darkdream Dec 11, 2013 10:48 AM
I bottomed out on a speed bump going at a crawl at an angle. I have multiple lowered cars and never bottomed out before, but this speed bump was ridiculously high and steep and I could not reverse with cars behind. I heard the loud thumb as the chassis hit the bump. I only see a small amount of the tar substance scrapped off. Is this to protection the chassis from rust? Where can I find some to reapply to the car? Anything else I should check that is not evident from a quick visual inspection?
ateens4 Dec 11, 2013 11:49 PM
If your car still drives in a straight line, not making odd exhaust noise, or leaking any fluids(motor or transmission oil), then you are fine. I was paranoid when I bottomed out on speed bumps, they're worse than dips and driveways because of the the "metal" sound it makes. Try to avoid speedbumps altogether:)
alphalanos Dec 20, 2013 03:04 PM
you can get rubberized undercoating spray at an auto part store. clean the area and spray a few coats and let it dry
© 2026 MH Sub I, LLC dba Internet Brands
