Car Felt Like It Hit Invisible Brick Wall...
Old May 21, 2003 | 07:43 PM
The Gasman's Avatar
Here's a thought, if you don't have three bars on the temp guage then vtec will not engage and the rev limiter will go off at around 6500rpm. I'm sure you haven't heard this before
Old May 21, 2003 | 09:09 PM
revhi's Avatar
I did the same thing once and it did scare the crap out of me. After I did it I looked for a reason in the manual and I couldn't find any warnings about it. It wasn't until I joined S2k.com did I really find out.
Old May 21, 2003 | 09:49 PM
JeffsS2k's Avatar
It is a freaky feeling. For some reason with an AEM intake it made LOUD whopping sound, then almost gives you whiplash.
Old May 22, 2003 | 12:59 AM
purdyS2K's Avatar
Banned
Why would anyone Vtec when the car is not fully warmed up at 3 bars?
Old May 22, 2003 | 01:48 AM
PWRMKR's Avatar
Ric,
So, do you think the above mentioned causes, was the cause?
Old May 22, 2003 | 04:06 AM
S2k001's Avatar
thanks a lot guys.. Well when I said "after I pulled out" i ALWAYS let me cars warm up (used to driving pretty modified cars) but she did have the heat all the way up WITH defrost on now that i checked.. (not to bright of a girl) anyways.. I believe that it may of dropped below 3 bars.. even though it was warm.. may of been at two... Thanks a lot for the advice guys.. this is the best forum i have ever been on.. take care
-ric
Old May 22, 2003 | 05:17 AM
ruexp67's Avatar
You let a passenger play with your control sufaces (even if it is just the temp controls.) and you call HER "not too bright?" What's next, is she going to set the radio too?
Rule #1: Don't touch the paint.
Rule #2: No food, drink or Smoke in the car.
Rule #3: Don't touch anything except the seat, floormat, and "Oh-Sh*T handle."
Rule #4: Hang on for dear life!
Old May 22, 2003 | 03:30 PM
boiler's Avatar
[QUOTE]Originally posted by ruexp67
[B]You let a passenger play with your control sufaces (even if it is just the temp controls.) and you call HER "not too bright?"
Old May 23, 2003 | 07:14 AM
dundonr's Avatar
I've found if you use good oil in the F20C1 you CAN go into VTEC before it hits 3 bars.. I've used Mobil1 since the 1st oil change and twice I've had to "hit it" before it got to the 3 bars and it would go to 9000 rpm with VTEC engaged just fine..
Old May 23, 2003 | 07:41 AM
lanbrown's Avatar
Dundonr,
Yep, noticed the same thing. It was either wait a very longtime and hope traffic clears or nail it. I waited long enough and nailed it, never went to 9,000 but did go above where it should have stopped.
There are many factors to when you can VTEC, the number of bars is not none of them, but can be used as a guide. If you run dino oil, when you hit three bars for coolant temp, then the oil should be warm enough to flow properly. Synthetic has a more consistent flow warm or cold, so the car allows you to rev higher sooner. Its not if you use a ?good? oil or not, but if its synthetic or dino.
Lance
